1970 442 / cutlass u joint replacement
Old Mar 24, 2021 | 10:43 AM
matviar's Avatar
Angry 1970 442 / cutlass u joint replacement
I am rebuilding a 1970 Cutlass convertible, and switching from the 350 engine and turbo 350 trans over to a 455 with turbo 400. I bought a new yolk for the driveshaft and test fit it OK to the turbo 400. Here is the problem. I purchased a AC Delco front u joint part #45u0106. that u joint does NOT fit into the new yolk. When I took the bearing caps off to fit it, it just doesnt clear the yolk ends like the u joint is slightly too long. ???? Any ideas?
Old Mar 24, 2021 | 01:26 PM
Can you post a picture, some clips go to the inside on the caps instead of the outside yoke groove.
Old Mar 24, 2021 | 04:57 PM
442Harv's Avatar
Are you sure you got a Olds yoke, and not a Chevy?
Old Mar 26, 2021 | 04:45 AM
matviar's Avatar
Im not sure about the yolk. I think I bought it from the parts place a few years ago. What's the difference between the chevy and olds yolk? This can be the whole problem. My car is a 1970 cutlass cv came with 350 engine and th350 trans. original non posi rear end. I replaced the engine with 455 ci. 400 turbo and rear end with o type posi. I took the drive shaft to the local mechanic to have the parts place yolk installed with new delco #106 u joint. He called back and said that u joint wont fit. I went there and He showed Me. When He took off the bearing caps it wouldn't fit into place like was too wide? He put on a different u joint and it worked. So I take the drive shaft back home and tried to install it. Slid it into the tranny and then it wouldn't fit the rear end like the shaft was about 1/2 inch too long. Sorry to write this into a story but just trying to explain. It seems the best solution would be to cot off 2 inches off the yolk, but I really don't want to try that.
Old Mar 26, 2021 | 08:53 AM
nicks1966's Avatar
How deep is the yoke in the transmission, some 400 have an o-ring on the output shaft that need a counter bored yoke.
did you measure to make sure the drive shaft was the correct length with your combination?
Old Mar 26, 2021 | 10:01 AM
Turbo 400 yokes are not that long, post a picture of yours.
Old Mar 26, 2021 | 01:07 PM
matviar's Avatar
I took the driveshaft and yolk(already assembled) to a driveshaft shop today and He is going to shorten it from 56 1/2 " to 55". That should be enough to allow for yolk movement in the tranny. Hopefully this works. THANKS!
mister-twister
Feb 12, 2020 09:30 PM
cdoering
Jan 8, 2019 03:12 PM
matviar
Aug 15, 2018 10:23 AM
Zr1bandit
Aug 7, 2017 07:33 AM
cdoering
Jan 26, 2015 01:57 PM
