1968 cutlass/ 442 fender eyebrow trim replacement
Old Feb 10, 2026 | 07:40 AM
nooldsyet's Avatar
I need to replace the eyebrow trim on my 68. I performed a search here (and elsewhere) on this topic. I saw a post dating back to 2007 in which one member stated one could get at the nuts from inside the engine bay, with a long extension (that may have been for a 69 only). I do have the chassis service manual... Just didn't want to take apart the front end to replace these if there is an "easier" way.
Thank you
Old Feb 10, 2026 | 09:34 AM
allyolds68's Avatar
Thank you
That was probably me.
The easiest way is to remove the fender but it's possible to get to all the nuts with a long extension and a lot of patience. Getting them back on is a lot harder than getting them off.
The eyebrow molding passes through both the fender filler and the fender so the studs naturally want to get bound up
Old Feb 11, 2026 | 06:04 AM
I've done this many times on the 68-72 cars. You need a long extension and a deep socket (to clear the studs on the trim). It requires a lot of tactile sensitivity to get the socket over the studs and stamped sheet metal nuts, as this is totally blind. A telescoping magnet will be helpful when you drop the nuts.
Old Feb 11, 2026 | 06:56 AM
allyolds68's Avatar
And remove the battery from the tray
Old Feb 11, 2026 | 10:02 AM
acavagnaro's Avatar
renting a borescope for a day might be a worthwhile investment.
Old Feb 11, 2026 | 12:04 PM
nooldsyet's Avatar
No borescope needed. Long 1/4" extension, 3/8" deep socket, battery out... All 4 came right off.. Thank you all!
Willswheels
Aug 29, 2023 02:26 AM
Platinum69
Jun 8, 2018 05:49 PM
c294mpd
Feb 14, 2016 04:18 PM
RJ3327
Apr 20, 2010 04:18 PM
69-Sguy
Oct 3, 2007 06:42 AM
