1967 olds cutlass oil
Old Dec 25, 2015 | 05:35 AM
Lucas Cowdrey's Avatar
Can't find anything on here but does anybody know the oil capacity of a 1967 cutlass with the 330?
Old Dec 25, 2015 | 06:08 AM
Five qts with a filter change.
Old Dec 25, 2015 | 06:11 AM
The first thing you need to get for this car is a factory Chassis Service Manual. They are all over ebay. Get an original paper copy. Repros and electronic versions are all based on scans of paper originals and often loose something in the translation.
Old Dec 25, 2015 | 07:38 AM
lemoldsnut's Avatar
I agree with Joe an assembly manual helps also. Best money you will spend and a resource you will use over and over.
Old Dec 25, 2015 | 07:41 AM
There are three manuals that will be helpful. The Chassis Service Manual is the highest priority, as it contains all the information needed to properly maintain and repair the car. The Fisher Body Manual is the second priority. It contains all the info on the body-related items such as doors, windows, and interior. The Assembly Manual is really just reprints of the factory engineering drawings and specs used to assemble the car. Frankly, I'd rate it a distant third in terms of priority for someone looking for maintenance information. The Assembly Manual is mandatory for a proper factory restoration, but less important and less useful for just performing maintenance work.
Old Dec 25, 2015 | 07:49 AM
... Of course, you could just add oil one quart at a time until it's up to the "FULL" line on the dispstick...
Old Dec 25, 2015 | 08:19 AM
And that's assuming the dipstick is accurate
Old Dec 25, 2015 | 07:27 PM
True. But you gotta go on faith every now and then.
Redog
Oct 20, 2015 03:29 PM
BeenThere
May 31, 2015 06:14 AM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
86pontiac
Feb 17, 2010 11:24 AM
