1965 olds cutlass gas pedal
i have a65 olds cutlass with a 330 2speed trans throttle mechanaism and would like to convert it to a cable throttle, is there away to install a different pedal and cablle ?also i will beputting a 425 motor in car and need to know which mtor mounts to use.. all help will be apprecieated
i have a 350 turbo in the car and i dont need the electrics for that trans also the throttle and trans bracket is very close to my gm hei distributor.idont know how its going to bolt up on my 425 intake and what clearance issues i may encounter, so i thought i would clean it up. whats your thoughts on my idea
The intake has nothing to do with the location of the distributor or the accelerator bellcrank. If your real question is about clearance of the throttle rod from the bellcrank to the carb where it passes the distributor, you can bend the rod.
I used the floating throttle pedal and bracket on my 65 cutlass,….bolt in. just need to get the right length throttle cable. mine is 4 spd so didn't need kickdown. newer olds cable brackets should be usable for throttle and kickdown when using newer trans.
i am going with a 350 turbo trans and want to clean up that old linkage, that why i want to go with a cable ,dont need all that contraption on firewall since i getting rid of the jetaway. hoping i can find what gm gas pedal will work. any ideas?
You might look at the throttle cable linkage used on the 6 cylinder 66 and 67.
I have that if interested.
Larry
Always best to email direct
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
