How to remove 69 Supreme Power seat??
There are two more bolts or nuts at the rear under the carpet. Opposite end of the track. Or you can remove the four bolts holding the seat to the track. Unplug the electrical supply first, so you don't go up in smoke! If you raise the seat as high as it will go first, then it is much easier to work on.
Thanks a lot!!
Finally got my driver seat out!
The problem was that my power seat motor was a little bit tired, so I thought the seat was full up, but I had to help it to raise it more!
Then I saw the 2 rear nuts!!
Thanks again!
Thanks again!
Christophe2m6
Mar 3, 2015 02:54 AM
