TRW 369P - 30 Pistons
Old Jul 3, 2014 | 10:22 AM
jevanstintshop's Avatar
Hi, I'm helping my father in law do a rebuild on a 1970 olds 455. It won't be a serious performance engine or anything other than a fairly small cam (Engle EP-18/20)and "C" heads that to my understanding are 80cc... The pistons that come in the master kit are TRW 369P - 30.. Does anyone know what the approximate compression ratio will be using these pistons????? The dealer selling the master kit isn't sure Thanks in advance!!
Old Jul 3, 2014 | 10:26 AM
coppercutlass's Avatar
Chevy budget Olds powered
Google compression calculator and you should be able to find one. There are many factors to claculate compression. Bore , stroke , deck height (how far the piston sits in the deck ) gasket thickness , piston cc's .
Old Jul 3, 2014 | 12:29 PM
Same answer I gave you on the other forum. Approx 13cc dish on those cast pistons. With true 80cc chambers and original shim head gaskets, around 10.0:1. With the more likely 83-84cc as-cast chambers and FelPro 0.040" head gaskets, closer to 9.25-9.5 CR.
Old Jul 3, 2014 | 12:35 PM
Be aware that 80cc head volume is an average number. A set of G heads that I have measured 85cc, so you really need to cc the heads to know for certain what yours are.
I found this info for the pistons:
http://www.summitracing.com/parts/slp-369p
Notes: Recessed piston head is 0.120 inch deep x 2.940 inch diameter.
Those piston dish dimensions calculate to 18.16 cc (assuming I did the math correctly).
edit: I didn't - it's 13.3 cc
Assuming the following:
80cc combustion chamber
.045" thick head gasket
4.250" gasket bore diameter
zero deck block
CR = 10.1:1
Increase the heads to 85cc
Increase the piston-to-deck to .025"
CR = 9.26:1
This shows why it is important to actually measure YOUR parts and not rely on average values for determining your CR.
Old Jul 3, 2014 | 12:40 PM
You might want to recheck your numbers - or show your work.
I get 0.8146 cu in, which converts to 13.3 cc, as I posted above.
Old Jul 3, 2014 | 02:45 PM
You are correct. I will edit the CR in the above post.
Old Jul 8, 2014 | 09:44 AM
Thanks... Not the greatest with the math but this info helps.. Thanks for replies!
gearheads78
Oct 10, 2010 01:23 PM
Daverd
Aug 17, 2010 10:56 PM
jensenracing77
Oct 15, 2009 05:24 PM
