Olds 260
Old May 19, 2014 | 06:30 PM
CranioPazzo's Avatar
Olds 260
hello i have an olds 260 v8 with a 307 intake...i was curious if anyone knows if itll bolt up to a turbo 350 trans???
Old May 19, 2014 | 06:55 PM
Yes it will.
Are you bolting it to a transmission to make it heavier, so it will serve as a better boat anchor?
Old May 19, 2014 | 06:58 PM
Redog's Avatar
A 260 will run, but that's about it.
Not known around here of being the engine of choice
Old May 19, 2014 | 07:09 PM
ok thanks....trans went and i have a turbo 350 outta a parts car...i have a 350 but i have to put the heads on and all that **** to get it ready to drop in...can any of the stuff off the 260 such as water pump, starter, fly wheel, pullies etc be put on the 350 or they wont match??
Old May 20, 2014 | 07:41 AM
hookem horns's Avatar
Never thought much about a 260, but think it uses the BOP bolt pattern like other SBO. Should work unless your TH350 has the Chevy mount.
Old May 20, 2014 | 08:59 AM
Every single Olds V8 from 1964-1990 has exactly the same bellhousing bolt pattern.
Old May 20, 2014 | 03:11 PM
nice thanks guys...i have to see if the TH350 has a BOP or chevy...it was bolted up to a chevy straight 6 from a nova so well see....
Old May 20, 2014 | 03:27 PM
In that case it has a Chebby pattern.
The only way it will work is if it is one of the relatively rare dual-patterns.
Old May 20, 2014 | 03:29 PM
ok...incase it doesnt do i have to get a new bell housing or an adapter?
Old May 20, 2014 | 03:36 PM
There are adapters, but TH350s are kind of a dime a dozen, and there's not a lot of torque behind a 260, so you might do better just getting a junkyard BOP model.
Old May 20, 2014 | 03:40 PM
ok cool....i also have another trans from a parts car thats BOP and has C4 on the top...unsure of what kind it is have to look at the pan bolt pattern
FlatFenders
Aug 23, 2014 08:04 PM
denale200304
Dec 17, 2012 08:48 AM
76 salon
Apr 16, 2012 11:06 AM
OldsMotion
Sep 17, 2009 09:42 PM
Alkoh0liker
Jan 1, 2009 07:42 AM
