cutlass wheel code
Old Feb 24, 2014 | 06:48 PM
mgobert's Avatar
cutlass wheel code
Trying to figure out which wheels came on my 72 Cutlass. Box 59 on my build sheet says HF and options show P01 wheel discs. Can anyone ID for me ? Thanks
Old Feb 25, 2014 | 02:30 PM
BlackGold's Avatar
Oldsmobile, like other GM divisions, recycled the option codes each year. So the P01 discs in 1972 might differ from those in other years.
Maybe someone will post a picture for you, but if you have a 1972 assembly manual (aka Product Information Manual), it'll have a chart listing the HF code wheels. It might also have a picture of the P01 discs. If it doesn't, chances are the Chassis Service Manual does. Both of these manuals are excellent reference material that you should own.
Old Feb 25, 2014 | 03:31 PM
442Harv's Avatar
My book, says it is F-85 wheel, part number, 9791450
Old Feb 25, 2014 | 03:54 PM
Mr Shifty Sidney's Avatar
HF is what I assume to be a standard 14 X 6 steel wheel.
PO1 wheel disc is pictured.
Don W
Old Feb 25, 2014 | 04:15 PM
442Harv's Avatar
Checked my book more. It does not show a 69, but shows a 68, and 70. They are not wire caps. The book says,14 inch, center dome with imprinted Oldsmobile logo with 6 oblong slots. Looks like to me the standard full size cap for 69.
Old Feb 25, 2014 | 06:57 PM
mgobert's Avatar
So is this cap for a 72, the one pictured ? My sheet also shows G70x14 BW W/L. Thanks for the help.
Old Feb 25, 2014 | 07:42 PM
The hub cap pictured is correct for 72.
Don W
Old Feb 25, 2014 | 08:03 PM
mgobert's Avatar
Thank you for the info. Mitch G
Bfg
Apr 1, 2013 04:47 AM
ros6872
Aug 28, 2012 09:53 AM
Boldsmobile
Nov 2, 2011 06:02 PM
rrielley
Feb 9, 2008 10:43 AM
OldsMotion
Mar 15, 2007 07:45 PM
