Water circulation ?
Old Jul 20, 2013 | 11:11 AM
jag1886's Avatar
Water circulation ?
Today I was at a car show and there where actually Oldsmobiles at it. I was looking at them and noticed about half had the rear of the manifold plumed to the front of the manifold. What does this accomplish, it looks like they are trying to even out the flow from the front to the rear of the head. Has anyone tried this and does it do anything?
Old Jul 20, 2013 | 11:36 AM
It tells me they bypassed the heater core.
Old Jul 20, 2013 | 11:47 AM
Probably too lazy to change it when it started leaking...
Old Jul 20, 2013 | 12:36 PM
bccan's Avatar
There is belief that coolant flow is a bit stagnant @ back of heads leading to increased temperature @ cyls 7 & 8. The hoses help evacuate the area & route it to front of engine sending it to the radiator via front manifold cooling passage or stat housing. I had one engine that was always on the precipice of preignition, probably more prone to those cyls.
I plumbed only the left side of that engine figuring that if the heater core is hooked up than at least #8 is getting good flow, simply connected rear coolant passage & front passage. With no heater, one would connect the right side as well. IIRC it did help & remember shooting things w/ IR thermometer & it did cool that back corner better but don't recall by how much.
Old Jul 20, 2013 | 12:53 PM
This is an ongoing debate on various automotive forums. Suffice to say that factory heater delete cars simply plugged those rear ports with no ill effects.
Old Jul 20, 2013 | 12:59 PM
... factory heater delete cars simply plugged those rear ports with no ill effects.
... And cars with A/C blocked those rear ports with a closed heat valve when on "Full Cold" A/C, presumably on the hottest days of the year, with no ill effects.
GAOldsman
May 9, 2013 08:08 PM
155thINF
Aug 25, 2006 05:30 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
