Alternator bracket interchange
Old Jun 14, 2013 | 05:40 PM
radioburningchrome's Avatar
I broke the alternator bracket on my 260 V8 with AC. What brackets would interchange?
Old Jun 15, 2013 | 06:57 AM
Depends on the year. The easy answer is any SBO bracket from a comparable year, but there may be more options depending on your exact year.
Old Jun 15, 2013 | 07:08 AM
Octania's Avatar
I'd say if it looks approximately like your broken one, it's right.
You found one via that thread, right?
There's the RH mount no-AC iron/steel bracket set, then LH mount steel brackets for with AC, then the G-body era set you have, which almost always have AC therefore LH mtd alternator. There are not a lot of different ones.
Possible exceptions: Toronado engines, and Pontiac 403 applications.
Any LH side AL bracket from the Olds car Olds V8 engine of the 78+ era should do for you.
Old Jun 15, 2013 | 12:02 PM
I found a 1985 Toro at the yard today, but the bracket was different.
Manipulated a steel bracket from another 260 I found at the yard. Year unknown.
Old Jun 16, 2013 | 07:55 AM
donor car
Picked over Cutlass provided the temporary bracket.
Old Jun 16, 2013 | 07:57 AM
With the help of a bandsaw, my temp bracket was ready.
442mark
Sep 30, 2017 01:06 PM
xerxes600rr
Aug 30, 2011 06:43 AM
cisco88
Cars Wanted
Mar 1, 2008 09:47 PM
Natas
Nov 24, 2007 06:07 PM
Natas
Nov 15, 2007 05:42 PM
