What's a fair price to buy this stuff
I can't tell, Is that a console lever? If the inside looks good I would agree with the $1000 area. Are you looking to buy this stuff or sell it?
Ratio adapter 40+ what ratio? .866 is hard to find.
bellhousing 100
reverse lock out parts 75+
flywheel 90
M-20 400-700, up to 800 for a great one
shifter/lever?
I am not a professional so carefull with my prices I listed.
bellhousing 100
flywheel 90
shifter/lever?
Thanks guys, I have an opportunity to buy it but the price is 2500. I'm thinking you can get pretty much everything reproduced right and spend 2500 so no big savings here.
I am doing a 4spd conversion on a 71 442 and is there anything that isn't reproduced?
I have a real nice 72 M-20 that has never been apart and was pulled in the 80s. bellhousing, non console original shifter, linkage, reverse lock out for $1000. All pulled from a 72 cutlass. I would consider the M-20 as needing rebuilt but I know it would work good if you installed it as is. I have discussed it with another member last fall so i would have to check with them before i could commit.
What is the difference between a console shifter and a non console shifter?
