Adding a/c to '70 w-30?
Old Apr 7, 2013 | 09:49 AM
jersey2phx's Avatar
Does ADDING (after markert) A/C to '70 w-30 diminish the value?
would it make a difference using OEM parts?
Old Apr 7, 2013 | 10:00 AM
66-3X2 442's Avatar
I think aftermarket A/C hurts the value where OEM does not. If it wasn't a W-30,it might not hurt as bad but unless it's a resto mod,aftermarket hurts IMHO.
Old Apr 7, 2013 | 10:14 AM
jersey2phx's Avatar
Are OEM a/c units readily available for a '70 w-30?
Old Apr 7, 2013 | 10:21 AM
Adding A/C to a manual trans W-30 DEFINITELY diminishes the value and will constantly raise questions of authenticity, since the manual trans cam won't generate enough vacuum to operate it and thus it was not factory available.
Old Apr 7, 2013 | 10:22 AM
66-3X2 442's Avatar
Not that I'm aware of. You will have to locate all of the parts from a parts car or somebody who has them. The A/c hoses have been reproduced by Classic Auto Air in Florida. I used a set on a 68 A/C car and they were very nice. They also have repo condensers/evap cores,they rebuild POA/expansion valvers. They also offer a cleaning/checking for leaks on OEM parts. If I had a 70 W-30 and wanted to add A/C,no way do I go aftermarket. Is your car an auto or stick?
Old Apr 7, 2013 | 10:46 AM
jersey2phx's Avatar
Im sorry it would be an automatic 1970 w-30
Old Apr 7, 2013 | 10:47 AM
jersey2phx's Avatar
automatic
Old Apr 7, 2013 | 11:22 AM
66-3X2 442's Avatar
OK,A/C was available on a 70 W-30 automatic car. As Joe posted previous to my asking,A/C was not available on stick 70 W-30's as he said. We were responding @ the same time,sorry for any confusion.
Old Apr 7, 2013 | 11:25 AM
jersey2phx's Avatar
ok but then on the broadcast card there wouldnt be any mention of the code for an a/c?
Old Apr 7, 2013 | 11:30 AM
66-3X2 442's Avatar
If the A/C code is on an A/C car broadcast card and yours is not an A/C car,then no,it won't be. That is if you have the broadcast card for your car as you seem to imply. Best thing to do is not worry about adding A/C,just save yourself a lot of heartache and trouble and just sell me the car CHEAP.
Old Apr 7, 2013 | 11:52 AM
jersey2phx's Avatar
WELL now that you mentioned "broadcast card". Having that, is good documentation? I mean not to be synical, but I have heard of those (broadcast cards) to be forged.....
Old Apr 7, 2013 | 12:05 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
For an OEM type installation,you might want to check into it. I think I remember reading the firewall where the heater box mounts is different between A/C and non A/C equipped cars.
Old Apr 7, 2013 | 12:23 PM
My442's Avatar
Correct. The firewall on the passenger side is totally different, and would have to be changed.
Then, you need to change:
1. The kick panels, and add the vacuum assembly on the passenger side
2. The entire internal heater box and heater core
3. The heater controls
4. All of the interior duct work and vents
5. The water control valve on the engine
Plus all the stuff under the hood.
It is a major undertaking in time, money and labor.
If you could do it for less than $3K, I would be surprised.
Old Apr 7, 2013 | 12:36 PM
66-3X2 442's Avatar
No,you mentioned broadcast card,I only replied to it. I have better things to do than worry about bogus broadcast cards,I'll let you and somebody else worry about that.
Old Apr 7, 2013 | 05:46 PM
Run to Rund's Avatar
I know it gets hot in Phoenix. Just leave the w30 in the garage and drive another Olds. Please don't add AC to the W30. Vegas gets nearly as hot, but mine doesn't have radio, heater, or AC.
Old Apr 7, 2013 | 06:25 PM
jersey2phx's Avatar
"don't add a/c to a w30"? unless using OEM parts
Old Apr 8, 2013 | 06:24 AM
dfire25's Avatar
"Trying to fix her right"
This is what happens when you try to add factory A/C to a factory heat car! (See pic) the knuckle head I bought my car from advertised it as a factory A/C car. After doing some inspection (unfortunately after I bought the car) I noticed areas in the firewall that were open. Leading to my conclusion that it was a factory hear car. He had the correct vents, boxes, and controls, but it was non functional. So I decided to rip it all out and install a vintage air unit. But then again, I don't have a W-30.
That being said, if I was hard pressed to have A/C in my W-30 I would do a vintage air unit instead of a factory A/C unit. It's a hell of a lot cheaper, plus it's not permanent. If you keep all the original parts, you could remove the aftermarket A/C unit and bring it back to stock at any time. If it can be removed then I don't think it would hurt the value. But like I said, I dont have a W-30 so its easy for me to say. Just my opinion
Steve Wike
Jul 17, 2009 10:19 AM
BLESSEDBYGOD
Mar 15, 2009 06:32 AM
JSGD1966
Oct 30, 2007 01:39 PM
perro
Sep 4, 2007 11:52 PM
