W Exhaust Manifold Needed 1974 Delta 88 w/ factory dual/ 455
Old Mar 29, 2013 | 12:41 PM
terrapin's Avatar
My left exhaust W manifold is cracked and I need to replace it. Was hoping to secure just this, not a complete W/Z set. I see a lot of options out there including reproductions, but would like to keep it simple and as low cost as possible.
Any insight would be great
Thanks,
Ed
Old Mar 29, 2013 | 02:51 PM
Octania's Avatar
Cracked manifolds can be welded.
There should be many used "W" LH manifolds available.
All will have other flaws like pitting, bad threads, broken ears, etc.
Old Mar 29, 2013 | 03:16 PM
bentlyf1's Avatar
I have one that i will sell as i'm buying a new set of reproductions. the manifold is in good shape no crackes or broken ears. $85.00 plus shipping
Old Mar 29, 2013 | 03:39 PM
terrapin's Avatar
85 bucks should work. I will send you a PM
Thanks,
Ed
Old Mar 31, 2013 | 08:08 PM
terrapin's Avatar
Ok guys need some more help.
I just removed the LH manifold on the car tonight and it is a 412887 part # X manifold. I did some searching and seems that this is not too far off from the W Manifold that I thought I had. Would anyone happen to know if the outlet angles and overall measurements are the same? My exhaust system functions fine the way it is now, but I could have a new down pipe made up to accommodate the angle change w/ the W manifold I guess.
I notice Thorntons makes a replica X Manifold, but it appears to be based on the earlier versions w/o dual chamber center ports and it also has a heat riser on it.
Ed
carmak
Oct 30, 2014 03:31 PM
Del70
Aug 9, 2013 03:40 AM
Andrew Morris
Sep 11, 2012 06:53 AM
orange442
May 25, 2011 12:03 PM
