Wheels and tires?
Old Mar 20, 2013 | 07:20 AM
tgilligan's Avatar
Wheels and tires?
70' Cutlass Supreme Holiday Coupe needs new wheels and tires. Looking to put her on some Cragar Eliminator 500's but what size tires would work in either scenario of 15x8 rim or 17x8 rim. Don't want to have to do any mods to the wheel tubs or fenders, but stock wheels on her now just are not cutting it. What size tire/rim combo goes best? I dont' want to have the low profile look but I also don't want it to look like I'm going the wide oval route either, not that there is anything wrong with either, just not the look I'm shooting for, somewhere in between.
Old Mar 20, 2013 | 07:34 AM
hookem horns's Avatar
I have 15" Cragar SS wheels that look similar but a little more old school. BFG 275/60R15 on 8" rims in back and 255/60R15 on 7" in front. They fill the wheel wells but can get a minor rub in front turning into a dip if the conditions are just right. Keep your stock rims for resale value or a change of pace.
Old Mar 20, 2013 | 09:21 AM
stevengerard's Avatar
I agree with Dane, my suggestion, no smaller than 15s no larger than 17s. That's a personal preference but even going up to 15s make a huge difference in look and ride quality. anything above 17s could end up looking too modern but try doing a search some guys have 20s on their car and it looks great.
Old Mar 20, 2013 | 10:03 AM
gearheads78's Avatar
car guy
I can't access my photobucket pics from work but I recently put 17 x 8 and 17 x 9 on a 72 Cutlass S I had. It looked great. You can see it if you look in this thread.
https://classicoldsmobile.com/forums...tml#post512607
Old Mar 20, 2013 | 03:35 PM
X2 on Richards, they did look good on there.
Old Mar 20, 2013 | 09:28 PM
hurst68olds's Avatar
Here's a pair of cars with CRAGAR 500Cs on them:
1968 Cutlass S convertible (I believe this is a members car) & I believe the wheels are 15x7.0" all around with 245/60/15 tires.
1968 Charger with 15x7.0" and 245/60/15 front & 15x8.0" and 275/60/15 rear.
I'm not sure exactly what you intended by not wanting the "wide oval" look, but with 7" & 8" wide wheels it's going to be difficult to not have wide tread/short sidewall tires on the car (especially with the 17" wheels). 8" wheels on the front need to be "well ordered" with proper offset or the tires are probably going to rub, inside or out.
Old Mar 21, 2013 | 04:41 PM
tgilligan's Avatar
Thxs everyone for the feedback and thxs Dane and hurst68olds for the tire sizes. Awesome to see the 500c's on the '68 and that's the look I'm going for. Point well taken about the offset for the fronts. Ideally, I was looking at 15x7 or 15x8 all around with a +4.00mm offset and 4.125 backspacing and trying to avoid the rubbing. Think this would cut it?
Old Mar 21, 2013 | 06:14 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Nice wheels,the 500's are my favorite non factory aftermarket wheel.
Old Mar 21, 2013 | 06:16 PM
ent72olds's Avatar
Registered Luser
You have to look at Richard's car before deciding! What ever combo he had, use exactly the same.....'Nuff said.....
Old Mar 22, 2013 | 11:48 AM
tgilligan's Avatar
Exactly what I'm looking for
Richard,
Thanks for posting as that look is precisely what I'm going for. Can you tell me what size tires are on the 17's? Also, what size offset and backspacing did you end up going with? Any rubbing?
Old Mar 22, 2013 | 11:53 AM
car guy
Originally Posted by tgilligan
Richard,
This is what I went with
http://www.ebay.com/itm/17x8-17x9-GR...ed2e2a&vxp=mtr
jnaarnold
Sep 12, 2017 08:09 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
morrowjm
Oct 10, 2010 09:39 AM
