Exhaust help needed
Old Mar 3, 2013 | 06:54 PM
sklbndt's Avatar
Exhaust help needed
I need to replace my exhaust. I may already have it figured out but am seeking confirmation. I have a 1968 cutlass convertible with a 1971 455 and W/Z manifolds. If I have a local shop, assuming I can find one, do a custom set then no problem. But if I order a pre-made set I'm thinking I should order a set for a 1971 442/W30 car. Have I got it figured out?
Any rear bumper differences that might give me tail pipe issues?
Any other issues I might run into?
Old Mar 3, 2013 | 07:04 PM
2blu442's Avatar
Hi John
The 1969-72 used the same manifolds, but the 1968 big blocks had slightly different shaped manifolds. I think if you ordered 69-72 exhaust you'd be OK. The tailpipes for your 1968 may need some different mounting brackets than the later years as they had tabs on the bumper brackets. Then your shop will need to line up the trumpets and weld them on. I had a shop get in a hurry on my 1970 and one of the trumpets ended up slightly rotated. So watch that closely.
John
Old Mar 4, 2013 | 06:59 AM
Just get an exhaust for a 1969 442. It will bolt in.
atkinsom
May 29, 2013 06:39 PM
cutlassclay
May 11, 2012 06:31 AM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
1971 442 convert
Oct 23, 2011 07:46 AM
WTony
Sep 14, 2010 10:07 AM
