SS-2 wheels
SS-2 wheels
This may be one of the dumb questions,
but I have to ask it...
On this 70 CS I have, it has the SS-2's with
drums up front. If I go with the disc brake swap
will these wheels fit over them? Thanks guys, Adam.
I wasn't sure but when the SS-2's were coming out,
I thought that they fit disc brakes, because the move
from GM to start the disc brake revolution was on, and
they moved from SS-1's to twos and threes, and wanted them
to fit over discs even if the customer didn't want to pay for
the upgrade. Thanks for the answer fellas.
I believe any of the 14 x 7 or 15 x 7 SSIIs or SSIIIs will work. IIRC some of the earlier 14 x 6 rims would not work. Of course that assumes you get stock sized disc brakes. If you get larger than stock brakes you will have to go with larger diameter rims
