455 valve covers???
Old Jun 16, 2012 | 03:15 PM
sxsleeper's Avatar
SXsleeper
455 valve covers???
I bought a set of roller rockers for my 455 and they are too tall for the stock valve covers. You may already experienced that, but I want to keep stock appearing! So what can I do? The tall ones from Mondello do not have the notches on the back side of covers and the holes are not in center.
Has anyone ever modified the baffles or been able able to use stock covers?
Thanx
Old Jun 16, 2012 | 11:12 PM
DeltaPace77's Avatar
I've seen where people have made up spacers to gain some height. Probably not expensive a thing as it once was, with the new plasma cutters, that are programmed by computer. While not roller rockers, my engine has a Dave Smith adjustible valve train kit and .560 lift cam. With M/T finned aluminum valve covers, one of the heavy stamped steel rockers is hitting the PVC baffle plate a bit, so it's tight. Not sure if there's any height difference between the aluminum M/T's vs the stockers, but had to modify the A/C bracket a bit to make things fit.
Old Jun 18, 2012 | 07:48 AM
sxsleeper's Avatar
SXsleeper
Deltapace77
Thanks for the info.
What Did you do To modify the ac bracket?
Old Jun 18, 2012 | 10:59 AM
Was awhile back so not 100% sure on what I did to the brackets. I have welding equipment, but wasn't anything to radical. Recall grinding the M/T cover corner a bit too. Know the guy doing the cover spacers is on the Corvette Forum, so I'll check into it. Can't promise anything though.
Old Jun 18, 2012 | 11:09 AM
droptopron's Avatar
delete
http://www.ramairrestoration.com/old...er-spacer.html
Here are spacers but look for clearance uissues on the brake booster & brackets.
Old Jun 18, 2012 | 05:04 PM
ziff396's Avatar
I used these or similar 3/8" spacers on mine. No problem with the brackets however, the brake booster being stock size would have to be moved to remove the cover.
Old Jun 18, 2012 | 06:09 PM
BLUE72RAGTOP's Avatar
I've stacked gaskets after gluing them with pig snot(the yellow glue). A little gain, anyway
Old Jun 19, 2012 | 07:33 AM
Did check with the guy on the Corvette Forum, and used spacers from Stefs Performance. The catalog pieces are 1.1" thick. Didn't see any Olds pieces listed, but they'll probably fab some up for you.
RAMBOW
Mar 20, 2017 06:58 PM
jpc647
Oct 12, 2012 03:11 PM
olds4life
Jul 4, 2010 05:57 PM
agtw31
Apr 17, 2010 09:22 PM
