1955 olds 88 visor sagging.
Old May 26, 2012 | 09:14 PM
Switch Blade Betties's Avatar
so my visor's are sagging making the car look like they are frowning. how do i fix this so they are tight up against the roof line?
Old May 28, 2012 | 02:22 PM
Tedd Thompson's Avatar
I have a convertible so this might be different in a hardtop car but don't you have sunviser supports? If not I'm sure you could install them to eliminate that problem. I think they are still listed in USA Parts Supply # S10-219A.....Tedd
Old Mar 21, 2013 | 11:02 PM
nope, they have no middle supports, right now i have removed them, but would like to pu them back on sometime.
Old Mar 22, 2013 | 12:42 AM
55/98's Avatar
If you flip the visor down and look at the end where it mounts you will see a screw head facing you ,tighten that scew until you visor is secure enough to hold its self up.worked on mine.
cisco88
May 4, 2011 10:24 AM
Olds Dad
Body work
Oct 15, 2010 11:50 AM
dallasite21
Aug 18, 2009 12:57 PM
case2273
Jul 16, 2009 02:02 PM
pakrat
Body work
Jul 11, 2009 10:20 PM
