Storage engine cradle
Old Jan 4, 2012 | 05:35 AM
sandcraft4's Avatar
Anyone know where I can purchase an inexpensive engine cradle? Also if anyone know the deminsions for building one for a 1972nOldsmobile engine? Thanks
Art
Old Jan 4, 2012 | 06:12 AM
Boldsmobile's Avatar
Art, you can build one for about $20 worth of 1" square tube. Do you have access to a welder? Ive built several myself and never build them by dimensions. Hang the motor from a cherry picker, bolt the 4 vertical mounting tubes to the engine and weld a perimeter around the bottom.
Here is the one i built. I did use 1" flat stock to bolt to the block and the 1" square tube is welded to the flat stock.
There is a very nice one here too. Also a mention of a chevy one modded to fit.
http://72.22.90.30/phpBB2/viewtopic....ighlight=bolts
Old Jan 4, 2012 | 08:18 AM
jag1886's Avatar
They are sold on EBAY and Amazon just type in Oldsmobile engine cradle.
Old Jan 4, 2012 | 09:24 AM
bigD's Avatar
i've got an allstar cradle and really like it! fits perfect & comes with all the hardware needed... bout $70...
Old Jan 4, 2012 | 11:06 AM
DeltaPace77's Avatar
As mentioned, you can get these at places like Summit and Jegs too. I welded my own togther from heavy angle iron, and the casters were most expensive part. If you pull the carb and dizzy off the engine, laying a piece of wood on it, makes a nice storage shelf. I had mine in a back yard shed, and a couple 2' x 8' plywood sheets, got me across the lawn. You're probably wanting better casters if going this route.
Old Feb 6, 2012 | 05:39 PM
sklbndt's Avatar
I built one out of wood (one 2x10x8 and one 2x4x8) and hardware (lag bolts and carriage bolts). Not a must, but I decided to add casters as well. This is for a 455 with a standard oil pan. Oil pan sits down inside and the engine rests on edges of oil pan where it meets the block. Check it out below. Note the notches for the front crankshaft end and the oil pan dipstick notch.
Old Feb 8, 2013 | 09:47 AM
squirell's Avatar
Govt slave
Is this the one you got ?
You have a small block or big block ?
Old Feb 10, 2013 | 10:06 AM
Indy_68_S's Avatar
I have one. Was like $65 added to my machine shop bill. Worked perfectly. Even had nuts welded on frame for bolt storage. Will fit BBO or SBO (since the lower halves of both are the same).
Old Feb 10, 2013 | 10:58 AM
squirell's Avatar
Govt slave
Thanks...I'm going to order it,I see Jegs carries them
Is this the one ?
http://www.jegs.com/i/Allstar+Perfor...10142/10002/-1
Old Feb 10, 2013 | 11:07 AM
RROLDSX's Avatar
Harbor Freight has their four wheel engine stand on sale for $45 if you use the coupons in any hot rod or truck magazine.
Old Feb 10, 2013 | 11:10 AM
Indy_68_S's Avatar
Is this the one ?
Yep. That looks just like it. (Although there's no name on mine so I can't be sure of the brand...)
Old Feb 10, 2013 | 11:16 AM
squirell's Avatar
Govt slave
thanks.
From what I see Harbor freight has stands not cradles
Old Mar 6, 2017 | 12:35 PM
llittles's Avatar
Question
Hi my name is Les. I just purchased a rebuilt 455 Olds and was looking to build one of these to help transfer from my truck to the engine stand. Basically something that the engine can sit in my truck bed while I take it to my house. I have engine stand for it but needed something to keep it in my bed for transportation.
Thanks,
Les
Old Mar 6, 2017 | 12:39 PM
llittles's Avatar
Just wondered if you had the dimensions of your stand you made which is cool, the rectangle box you built where it touches. I have to make one this week figured you know. Thank you I appreciate it.
Thanks,
Les
Old Mar 6, 2017 | 12:51 PM
RROLDSX's Avatar
I built two pairs of these out of 1" square tube. They work well and bolt to the side of the block.
Old Mar 6, 2017 | 02:02 PM
RetroRanger's Avatar
72 Olds CS
this thread had additional dimensions for DIYers
https://classicoldsmobile.com/forums...ge-cradle.html
Old Mar 7, 2017 | 10:13 AM
F-85 4-4-2's Avatar
I highly second the recommendation for the Allstar Performance ALL10142 Heavy Duty Engine Cradle for Oldsmobile. Bought mine on Amazon Prime, delivered for $81.99.
Amazon Amazon
Bought a set of these steel wheels, too. They work great, and no concern with flattening.
http://www.ebay.com/itm/172444463827...%3AMEBIDX%3AIT
1968_Post
Mar 14, 2015 07:08 PM
TexasGunner
Aug 14, 2013 03:24 PM
dephconn24
Body work
Feb 12, 2012 02:11 PM
Mark71
Feb 12, 2012 10:00 AM
DENT
Feb 10, 2012 08:18 AM
