Electric Fan
I was going to use lighted switches, one for each fan. The switch HAS to be lighted while running.
x2 on 68conv. It is best to use relays. For they take the load of the fan , not the switch. That way the switch is only an on/off. The switch turns the relay on and the relay supply's power to the fan.
Gene
Gene
Your local auto parts store should have relays. Similar to this one:
http://www.bgmicro.com/REL1068.aspx
They need a 12V coil, and 30-40Amp contacts.
