Help needed removing Toronado rear spindle
Old Jan 9, 2011 | 09:36 PM
2blu442's Avatar
I'm trying to remove a spindle from the rear axle of a 1966 Toronado for another member here. I checked a 1967 Chassis Service Manual thinking it would be the same as in 1966. It sounded like once I removed the backing plate I should be able to knock it out with a hammer. I've tried wacking it with a big hammer, soaking it with Kroil, and the big hammer treatment again. No sign of movement. Am I doing something wrong? Did the 1966 have a different setup than the 1967? I've got the axle out on the ground now and here's a few pictures of my lack of progress removing the spindle. Any ideas?
Old Jan 10, 2011 | 05:52 AM
66400's Avatar
My 66 CSM has the exact wording as the 67 CSM; "Drive spindle out of axle, with a hammer". Bigger hammer and/or heat with a torch.
Henry
Old Jan 10, 2011 | 07:48 PM
2blu442's Avatar
Thanks Henry, next weekend I'll dig out the torch and give that a try.
John
cheven
Jun 15, 2014 11:59 AM
Goonz55
Mar 22, 2013 06:02 PM
oldzy
Brakes/Hydraulic Systems
Mar 31, 2011 05:10 PM
64starfire
Suspension & Handling
Aug 28, 2010 12:36 PM
perro
Sep 3, 2007 01:30 PM
