Engine noise
Old Aug 29, 2010 | 02:34 PM
ELECMAN's Avatar
Engine noise
I hear a pinging noise from the motor on the driver side.only happens when i gun the gas,i changed the gas to 83 octane no change.doesn't happen when normal driving.i have a 455 motor in the car i think the timing is a little advance.the pistons are 20 over and a little cam work as per last owner.what should the timing be at thanks.
Old Aug 29, 2010 | 05:01 PM
442Harv's Avatar
If you have a different cam than stock, you can't use the factory timming. Aftermarket performance cam will need more timming than a stock cam. Advance it as much as you can without pinging.
Old Aug 29, 2010 | 05:15 PM
442much's Avatar
Go to a higher octane rating. The minimum around here is 87 then 89 and then 93. That could be the problem right there.
Old Aug 29, 2010 | 05:21 PM
m455sx's Avatar
Olds Nut
add some octane boost, if it is a daily driver then just reduce the timing a degree or two
cycomiko
Aug 24, 2014 08:46 PM
Mortimer
Dec 16, 2013 07:06 AM
Dan K
Apr 24, 2013 12:44 PM
MDchanic
Aug 16, 2012 07:38 AM
Redog
Mar 7, 2008 02:34 PM
