Car starts in any gear
Old Jun 18, 2010 | 08:40 PM
ELECMAN's Avatar
What does this mean when your car starts in any gear and how do you fix the problem thanks.
Old Jun 18, 2010 | 08:44 PM
compedgemarine's Avatar
has it always done it or is this new. if it is new the neutral safty switch may have broken and is staying in the park position. if it has always done this it could be a broken switch or someone may have it bypassed with a jumper wire.
Old Jun 19, 2010 | 08:07 AM
Is this a floor shift or column shift? If it's a floor shift, I bet the backdrive linkage from the trans to the steering column is missing. Alternately, someone has disconnected the neutral safety switch and jumpered across it.
Old Jun 19, 2010 | 08:30 AM
Cecil Anderson's Avatar
If it is auto trans make sure it is in R when you start it in the garage. unless you backed in Andy
Old Jun 19, 2010 | 02:42 PM
ELECMAN's Avatar
floor shifter,Is this bad if its not connected the right way
Old Jun 19, 2010 | 03:11 PM
It means that your backup lights won't work either. Also, the shifter does not lock with the ignition. It's not the end of the world, but unless there's some reason the backdrive linkage was taken out (headers, for example) there's no reason not to put it back in.
Old Jun 19, 2010 | 07:30 PM
MJAKS462's Avatar
You should fix it now. This is how your family gets run over by mistake.
What if your wife or teenager started it with the gas pedal depressed and someone was behind the car when it was in reverse.
Very dangerous situation
Old Jun 20, 2010 | 07:02 PM
agtw31's Avatar
your backdrive is gone
i had the same problem on my old 72 ragtop,guy removed the backdrive to put headers on.
Old Jun 21, 2010 | 09:09 AM
ELECMAN's Avatar
Ok I have w and z exhaust headers on the car in a floor console where is it located and if anybody have pics It would be helpful
Old Jun 21, 2010 | 11:06 AM
You have W/Z exhaust MANIFOLDS. These will clear the backdrive linkage no problem. Look at the end of the steering column on the engine side of the firewall. There should be an arm sticking out of the bottom of the column (above the upper U-joint). The backdrive linkage is a metal rod that runs from this arm down to an equalizer cross bar that runs from inside the frame to the trans.
Greeley
Jul 23, 2012 12:47 PM
glord
Sep 3, 2011 06:57 PM
gthmcty1
May 27, 2009 06:37 PM
sama87
Mar 29, 2009 04:07 PM
emarkay
Nov 14, 2005 09:13 PM
