Stock shifter to Hurst Dual gate
Old Apr 3, 2010 | 05:52 PM
#171Cutlassman's Avatar
What is the diff between the stock shifter cable and the dual gate cable?
Are there different brackets on the trans?
Old Apr 3, 2010 | 06:54 PM
jensenracing77's Avatar
i don't know this one but wondered the same thing. i always thought they were the same but not so sure now.
Old Apr 3, 2010 | 07:14 PM
svnt442's Avatar
The cable end at the shifter is longer on the dual gate. You can't use the standard cable with the dual gate in any way.
The bracket on the trans is the same for either cable.
Any other questons on installing the dual gate just ask.
Old Apr 24, 2010 | 06:33 PM
Thanks Randy,
Old May 15, 2011 | 01:54 PM
what are other dual gate shifter cable options? my cable is longer than the standard automatic cable but is not long enough to work. i had to mount my shifter and console about 1/4 inch back from where it would have originaly been but the cable is about 1 1/4 to short. what is the correct length i need for a 70 cutlass?
Old May 15, 2011 | 09:08 PM
svnt442's Avatar
Good question...
Found this. Second post.
https://classicoldsmobile.com/forums...te-1970-a.html
Old May 16, 2011 | 02:17 AM
thanks, i must not know how to use the search. i can't ever find anything.
Old May 16, 2011 | 12:12 PM
svnt442's Avatar
I actually found that using Google.
Old May 17, 2011 | 02:21 PM
i just called Fusick, they got one off the shelf to check the length for me. mine is 29 3/4 and his was 31 1/2 (eye to eye). that was my problem and i got one coming.
Fusick is so helpful and professional, i am glad they are there for us.
Old May 17, 2011 | 05:26 PM
dallas*fan's Avatar
hey guys
im doing the same convert from colum to floor tho.is a new speedo needed? i was told it may be, anyone have and extra bracket layin around you'd like to sell.is there anyone that reconditions the dualgate shifter?
Old May 17, 2011 | 07:18 PM
GAOldsman's Avatar
"Car"mudgeon
Hurst will recondition their original dual gate for a fee. Call them up to verify and print off the form to fill out and submit with your shifter.
http://www.hurst-shifters.com/c.7230...r_rebuild.html
Scotty B
Sep 10, 2024 04:57 AM
RS3SDL2MG
Hurst/Olds
Oct 7, 2009 05:42 PM
1968 42
Apr 3, 2008 05:15 PM
