Exhaust manifold ques.
Old Mar 15, 2010 | 07:58 AM
ELECMAN's Avatar
Let me ask the right ques.the previous owner had a 350 engine in the car.changed it to a 455 engine.he reused the 350 exhaust manifold on the 455 engine,not a good thing.he installed a whole new exhaust system using the 350 exhaust mabnifold gm #38001.i just purchased w & z exhaust manifold.would the pipes bolt up to the new w&z heads with no problem or do i need adapters.
Old Mar 15, 2010 | 09:45 AM
Oldsmaniac's Avatar
I am not sure the bend in the pipes would be a perfect match to bolt right up as the 350 manifolds did. I would say its going to be trial and error. A muffler shop should be able to fix or correct things if need be.
Old Mar 15, 2010 | 10:50 AM
svnt442's Avatar
The issue you're looking at is the W/Z manifolds are longer than the standard manifolds. The pipes should bolt up just fine, but they will stick down a bit too far. A muffler shop would be able to shorten them but the problem would be getting the flare right so they can be re-attached to the manifolds. You'd be better served getting new down pipes.
atkinsom
May 29, 2013 06:39 PM
ELECMAN
Apr 5, 2010 07:14 PM
ELECMAN
Feb 13, 2010 03:08 PM
ELECMAN
Nov 30, 2009 09:26 AM
