Spark Plug Questions
Old Mar 27, 2024 | 11:06 AM
NoVA_69_442's Avatar
I'm doing a spring tune up on my 69 442 w/455.
I swapped the spark plugs out, first time since I bought her (2020).
I provided a pic, just wanted to see if anyone had any input on how to read them, if they are fine or if I'm running lean/rich.
Thanks for any input.
Old Mar 27, 2024 | 11:51 AM
69455's Avatar
they look old
you need to read fresh plugs
Old Mar 27, 2024 | 01:03 PM
Quite (possible) likely you're adding an octane booster which often demonstrates the color you're witnessing.
Old Mar 27, 2024 | 01:23 PM
Originally Posted by 69455
they look old
Look again, the electrodes aren't worn at all. I can't say that I've ever seen brown deposits like that. And I assume these are platinum or something, not regular metal electrodes.
Old Mar 27, 2024 | 01:35 PM
mpowell's Avatar
If i make out the numbers right they are Bosch WR9FP platinum plugs. Never used them myself. Start fresh with some AC Delco's.
Old Mar 27, 2024 | 01:37 PM
69455's Avatar
Sooo your saying wrong plugs, is issue ?
Looks like old **** built up.
Old Mar 27, 2024 | 01:47 PM
Specifically, it's the MMT (Methylcyclopentadienylmanganesetricarbonyl) additive used in high octane booster solvents which creates the discoloration. The Internet is replete with images, suggestions, ratios, etc. using MMT. What someone does w/ their own engine is their own decision. If you have a street engine there's really no need for any octane booster, IMO. If you have a race engine, use race (octane) fuel. Let's face it, someone racing a race engine isn't waiting around four years to change spark plugs.
Old Mar 27, 2024 | 01:51 PM
Really can't see what the electrode looks like at that angle. Outside of being dirty, can't tell what shape they are in. Bosch Platinum plugs should last quite some time with limited driving, if the engine was running well clean them up and re-install.
Old Mar 27, 2024 | 03:51 PM
Actually, you can.
Old Mar 27, 2024 | 03:56 PM
No, just an observation. The shape of the center electrode is consistent with platinum plugs. Personally I use conventional plugs because a) I'm a cheap SOB and b) I change plugs often enough that there's no reason to spend the money on platinum or iridium or any of the other exotic plugs. Keep in mind that these exotic plugs were designed to fire emissions-friendly mixtures and meet tailpipe standards after 100,000 miles without a tuneup. This is what a plug with built up crud looks like, which is not what you are seeing in the OP's photo.
Old Mar 27, 2024 | 04:09 PM
BlueCalais79's Avatar
Same here. My 79's get green & white stripe Delco R46SZ plugs. No iridium or platinum. I just changed mine yesterday and they looked eerily similar to Nova 69 442's. They are already on their way to the landfill or I'd have snapped a photo. I also changed the rotor/cap with correct NOS Delco parts. Seems like I just tuned the car up, so I looked up when I actually did the last tune, which was just before the 2021 Nationals. Man, nearly 2 years flew by. My 260 is running noticeably smoother, as I bet Nova's will too with a fresh set.
Old Mar 27, 2024 | 05:00 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yeah, I used the Bosch Platinum with pretty good success. I used to see them everywhere, haven't seen them in years. The center electrode is tiny, that is mostly the electrode cover you see. The actual electrode is the size of pin head. My go to spark plugs are NGK. I find they provide a slightly smoother idle than the Chinese AC Delco and Autolite.
Old Mar 28, 2024 | 05:08 AM
Exactly. That's why I go after and use the green stripe made in USA plugs in the Acniter boxes. All white Delcos, no sale. The new plugs are just not as good.
Old Mar 28, 2024 | 03:58 PM
Horsepower's Avatar
Spark plugs
Actually the burn color is almost perfect your jetting and air fuel ratio looks pretty good. Won't hurt to change them though.
Old Mar 28, 2024 | 04:02 PM
All thanks for the replies. I have by using octane boost with lead additive. Maybe I’ll skip the octane boost for a while, check the plugs in a bit. I did swap in some new plugs for this season, so we’ll see how they do. Thanks again.
Old Mar 28, 2024 | 11:54 PM
OLDSter Ralph's Avatar
You ran the plugs for 4 years ? I don't see anything wrong with them. You could try one step hotter range, but I am not sure it would be worth the bother. Do whats been working.
Old Mar 29, 2024 | 06:11 AM
Sugar Bear's Avatar
Good call Norm a/k/a Vintage Chief!
Old Mar 31, 2024 | 10:42 AM
cjsdad's Avatar
I always download something like this when I change plugs. I can tell what oil-fouled plugs look like but can never remember what color means what. There are lots of different versions of this amd some are more detailed than others, but they all help.
pettrix
Mar 20, 2023 05:56 PM
friesjh
May 26, 2022 04:43 PM
chasman414
Oct 30, 2014 03:15 PM
72442clone
Jul 15, 2011 11:53 AM
ralsy
Aug 27, 2010 01:07 AM
