Front Brake Drum Hub bore - Flare vs flat (GM)
Old Dec 8, 2023 | 08:05 AM
Del70's Avatar
The NOS GM Chevelle front drum and original GM Chevelle front drums I have do not have flared pilot holes. The drums fit snug to the hub collar, and have zero side to side play on the hub. Two different after market drums I have/tried both have flared pilot holes. I Noticed that raised pilot hole (flared edge) sites slightly above the hub collar, and allows the drum to move side to side some. (no lug/tire installed . I have seen that flared pilot on rear drums. What is the purpose of a flared pilot hole in a front drum?
Old Dec 9, 2023 | 08:49 AM
67OAI's Avatar
Old(s)GuysRule
The 9 inch Chevrolet front drums, if I recall properly, are not attached to the wheel hub via swaged wheel studs as on other GM vehicles, probably a cost cutting measure. Thusly to maintain good concentricity with the hub they must fit snugly on the wheel hub center.
Gpc1
Sep 17, 2019 09:14 AM
Big Daddy Spo
Brakes/Hydraulic Systems
Feb 24, 2018 05:55 PM
Koda
Feb 20, 2017 03:07 PM
1969cutlazz
21
Jan 7, 2013 05:08 AM
Kensey
Jun 2, 2009 01:31 PM
