Convertible Top
Old Sep 11, 2023 | 07:56 AM
Harp 1's Avatar
Convertible Top
So the other day I replaced the electric motor on my convertible (75 Delta 88). When I hit the switch the top only goes up about less than halfway. Am I missing something ?? Any input will be very helpful. Thanks
Old Sep 11, 2023 | 10:28 AM
acavagnaro's Avatar
Could be several things. Most likely is that you failed to bleed the system properly and have air in the hydraulic lines. There is an excellent recommended bleeding procedure in the Fisher body manual.
Old Sep 11, 2023 | 11:13 AM
vCode442's Avatar
Vincit qui se vincit
Try this
Old Sep 11, 2023 | 02:29 PM
cfair's Avatar
When bleeding, it’s perfectly safe to put it up & down a few times per procedure.
If you go much more than 6 or 8 cycles put your hand on the motor to see if it’s getting hot. If so, take a break to let it cool down. Then finish bleeding later
Chris
Old Sep 11, 2023 | 03:03 PM
Falkon's Avatar
The '75 Delta 88 didn't have a pump. It used an electric motor w/ the scissors top I believe. A reason I never bought one. Are both of the cables OK? ClassicOldsmobile.com - Search Results
Old Sep 11, 2023 | 04:05 PM
Here is an excellent read on an ELECTRIC convertible top. I suggest you read it from beginning to end. Suspect one of the relays is bad.
https://classicoldsmobile.com/forums...onv-top-67385/
Old Sep 11, 2023 | 04:30 PM
One more for you w/ excellent images of the relay, etc. Good thread - I'd suggest it's worth the time...
Scissor Top R&R
Old Sep 11, 2023 | 04:54 PM
vCode442's Avatar
Just topped off my pump and bled the system, unaware that it didn’t apply to you and your Delta, but now, thanks to CO - enlightenment!
Old Sep 11, 2023 | 07:53 PM
nsnarsk65cutlass's Avatar
Yup, scissor type no hydraulics on that one.
Old Sep 11, 2023 | 11:23 PM
Falkon's Avatar
Installing a New Scissor Convertible Top • Muscle Car DIY
Harp 1
Jun 27, 2023 05:20 PM
chrisntam
Apr 3, 2016 07:18 PM
carnell71075
Sep 20, 2015 02:10 PM
Last98
Aug 23, 2013 07:25 PM
69convertible
Body work
Oct 15, 2009 04:27 PM
