Mystery Wagon Frame Braces?
Old May 17, 2023 | 03:49 AM
fjwhoopie's Avatar
Hello everyone, I remember seeing in the Oldsmobile Chassis Service Manual pictures of front frame braces used on the Cutlass wagons for 70-72. Has anyone ever seen these on the cars? Just always wondered about that. Thanks
Old May 17, 2023 | 06:24 AM
If you are talking about the diagonal cowl braces used on the Vista Cruisers, yeah, every 1970-72 Vista came with them. Note that the page from the PIM says "4800 only", which is the Vista Cruiser model designation.
Old May 17, 2023 | 08:20 AM
fjwhoopie's Avatar
Old May 17, 2023 | 08:21 AM
fjwhoopie's Avatar
I am aware of the upper fender braces, seen them before. I remember seeing lower braces attached to the frame in the front of the car, also not the rear frame braces on some four speed cars. Thanks
Old May 17, 2023 | 08:30 AM
Are you talking about these, used only on 455 2dr cars?
Old May 17, 2023 | 08:40 AM
fjwhoopie's Avatar
No, I have those on my 442 and four speed car, I will find the picture later on, they are under the car in the front of the frame under the motor to strengthen the frame.
Old May 18, 2023 | 05:43 PM
fjwhoopie's Avatar
Here is the pics ...
Old May 18, 2023 | 05:47 PM
Hairy Olds's Avatar
Shoveling Snow
These are for big body cars.
Old May 18, 2023 | 05:51 PM
B-body is the Delta 88
C-body is the Ninety Eight.
Old May 19, 2023 | 07:13 AM
Oldsguy's Avatar
Past Administrator
Just curious about the frames in the first picture, my Vista has them and the drive side brace interferes with battery maintenance/removal although minor. My question is this, why are the necessary?
Old May 19, 2023 | 10:22 AM
CustomBruiser's Avatar
My 82 Custom Cruiser has them. I had to remove the rears to clear long tube headers.
Old May 19, 2023 | 02:20 PM
VC455's Avatar
Barely Registered
Dan, I've always assumed they took visible shake out of the fenders/hood. But I'm no expert in this area of engineering.
I will be interested in Joe's take. Mr. Structural Engineer always gives us a logical explanation.
Gary
Old May 19, 2023 | 03:03 PM
Gary
My thought is that the longer wheelbase of the Vista, coupled with the higher probability that the wagon would be actually used as a wagon (hauling stuff), led to the use of those diagonal braces to stiffen the front end against a torsional mode. Frankly those struts aren't particularly structural. More likely they are there to raise the natural frequency in torsion to avoid a suspension mode that might hit resonance and cause an NVH issue.
Old May 19, 2023 | 09:34 PM
cfair's Avatar
I think I’ve asked this before, but while we’re on topic of firewall / fender / radiator support braces…
Is there any point in adding them to my ‘66 big cars? My ‘66 98 convertible shakes a bit on the freeway, I’ve been curious for years as to whether braces might help that. I’m not too optimistic though, since convertibles are, well, a structural compromise. And really, how much could a couple of 1/2” or 3/4” tubes really reduce shake?
Hypothetically, if I were to brace the radiator support or fenders to the firewall I’d put a support piece on the firewall to thicken it a bit, but it’s probably all for nought.
It’s just that I’ve observed braces in C*ddies and other GM’s of similar & later vintages and wondered whether adding them could do me some good.
Joe P, if you choose to indulge me, many thanks. I believe you’ve weighed in in the negative before. And I have every reason to trust a structural engineer on these points.
Cheers
cf
Old May 20, 2023 | 05:32 AM
Oldsguy's Avatar
Past Administrator
Joe, that does make sense. I don't see those two long rods doing too much structually to the front fenders/core support over a stock installation and the wheelbase difference between coupe/sedan/wagon is mostly after the firewall if not completely; so your theory of resonance makes more sense.
Old May 20, 2023 | 05:48 AM
This is especially true when you remember that the attachment of the core support to the frame is rubber bushings, so these do exactly nothing structurally. Non-structural engineers frequently don't understand the difference between stiffness and strength. Glass is stiff but not strong (usually). A willow is strong but not stiff.
g_field07edd
Vista Cruiser & Wagons
Aug 22, 2018 05:38 AM
Rustbucket2
Aug 28, 2017 09:48 AM
woodbine
May 16, 2017 04:37 PM
crazy'boutOlds
May 3, 2011 09:07 AM
Lady72nRob71
Dec 19, 2009 02:11 PM
