Throttle cable
First remove all the carpet, padding, etc. so you can see the piece from inside the car. Then look at the cable attached to the throttle pedal. There's a round plastic grommet in the pedal that has a cut on one side, push the plastic piece toward the seats and out of the pedal assembly. Spread the cut to take the cable out. Then there's a square hole in the firewall and the cable has two sides that have flared pieces that are spread to hold it in. I've had the best luck using two small standard slot screwdrivers to press them in and push it out into the engine compartment. I know you'll be standing on your head to reach this, but with some patience this should work. If my description of the two flared sides is not clear you might try logging onto one of the repop web sites to find a photo of it. John
