Rayloc remanufactured starter
Old Feb 21, 2022 | 01:38 PM
Donaldbabineau's Avatar
I am having starter issues. My 455 usually starts, but increasingly the starter either clicks or spins without engaging the flexplate gear. I was checking out starters at NAPA and their remanufactured starter listed is a Rayloc 246-4800. Does anyone know if this is correct for a 71 cutlass 455? The block originally came out of a 73 of unknown model. The block casting is a F serif (no A), so should be consistent with a 71 if that matters. Also, is this a good brand starter?
Old Feb 21, 2022 | 01:42 PM
70W-32's Avatar
Replace your solenoid first, your symptoms point to a bad solenoid. Buy yhe best one they have.
Old Feb 21, 2022 | 01:44 PM
You may get away with just a simple repair of your current starter. Just replace the starter solenoid and the starter drive, both can be bought at your local parts store.
Old Feb 21, 2022 | 01:55 PM
it's only $20 more for the whole assembly. I am not going to do the work myself (too weak after covid) and want to be sure to have the parts necessary when I bring it to the shop. I want to replace the whole unit which is currently a marine starter (The second home for the 455 was a jet boat), and solenoid and drive may not be compatible.
imcgm
Aug 20, 2015 09:20 AM
gtaa9
Jul 16, 2015 11:24 AM
70cutty
Aug 18, 2013 05:28 PM
timothypaul
Aug 2, 2013 07:40 AM
88hurstolds
Jan 11, 2013 07:43 AM
