Door hinge rebuild
Old Feb 16, 2022 | 08:37 PM
tkcutlass's Avatar
Door hinge rebuild
After rebuilding the door hinges the upper hinge has some up and down movement (play). The bushing went in tight but once in, it will move up and down slightly.
I'm thinking that might be a problem.
Old Feb 17, 2022 | 08:53 AM
Love1955oldsmobile's Avatar
The weight of the sagging door has likely sprung the hinge. Use a large vise or a trusty hammer to adjust the "wings" of the hinge to remove MOST of the play.
There needs to be a little play to prevent the door from binding.
Also soak the oil-less bushings in some light oil. Who knows how long ago they were made and the oil has evaporated.
Some of the non-box hardware stores sell brass washers one could use to remove the play without adjusting the hinge "wings".
Ron
Old Feb 17, 2022 | 09:34 AM
RetroRanger's Avatar
72 Olds CS
I wonder if the bushing hole is elongated from the last bushing wearing thru.
Old Feb 17, 2022 | 09:42 AM
tkcutlass's Avatar
bushing hole was round but once tapped in the new bushing can move up and down in the hole
Old Feb 17, 2022 | 11:12 AM
Up/down motion is irrelevant. Gravity holds the door down, and only one of the two hinges will actually carry the vertical load. Radial motion is what matters. That should be very tight.
Sep 28, 2018 02:49 AM
72455
Body work
Sep 26, 2018 10:32 AM
Del70
Apr 30, 2018 03:41 AM
tcolt
Nov 4, 2017 10:53 PM
Bfg
Aug 13, 2014 05:17 PM
