88' olds cutlass F41 suspension
Old Dec 25, 2021 | 10:52 AM
Redjetty's Avatar
I just recently bought a low mileage 88' olds cutlass supreme classic brougham, only 17,000 miles. Im changing all the fluids, belts, hoses, etc,,,now I am up to changing the shocks as it still wears the originals. The original window sticker says it has and upgraded F41 suspension. firm ride shocks, larger stabilizer bars and higher rate springs...My question is what kind of shock should I put on? No interest in racing or cornering on 2 wheels. Would like a nice soft ride to firm enough when needed..... Brands ?? I dont want heavy duty shocks do i? just because they came with firm ride shocks and the F41 susp..... I'd like something to complement the F41 without a hard ride,,,, thanks,,, merry christmas,,,, df aka rj
Old Dec 25, 2021 | 11:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Be thankful someone checked off the F41 box. My 88 didn't have it, handled pretty badly, others have found the same. Honestly, buy something like a top of the line, heavy duty shock, brand of choice. I bought the Monroe Sensatrac shocks. The shocks on my 88 were Econo white unmarked shocks, all replaced at some point and none leaking. The Sensatrac made a notable improvement. A lot of guys go with the KYB adjustable shocks with adjustable **** for ride firmness. Good luck.
Old Dec 25, 2021 | 12:41 PM
fleming442's Avatar
F41 is just upgraded sway bars. The G body front springs are marshmallows. The best shocks are Bilsteins, but you'll pay for them. You can get away with a lesser shock if you change springs. I've always had good luck with KYBs. I'd suggest some Moog 5660s and KYBs over stock springs and Bilsteins.
Old Dec 25, 2021 | 01:08 PM
Try it without the rear bar and bigger front, handles like a washing machine. I thought the F41 had slightly better spring rates, like 346 pounds per inch up to 420 as part of the package. Also the regular vague steering box also sucks. As said go with the best shocks you can afford.
Old Dec 25, 2021 | 01:28 PM
HighwayStar 442's Avatar
X2 Monroe Sensatrac shocks. Good for all types of driving. Have them on all my cars. Including 1987 Custom Cutlass.
Automatically adjusts to road conditions for soft ride and firm handling. All in one.
Old Dec 25, 2021 | 01:32 PM
RetroRanger's Avatar
72 Olds CS
What a nice looking g body, 17 k miles and it looks it.
Old Dec 25, 2021 | 02:57 PM
Redjetty's Avatar
F41 explained from build sheet
Old Dec 25, 2021 | 03:02 PM
Redjetty's Avatar
I cant find the x2 monroe sensatrac for my 88 anywhere,,, can you give me a part number off yours?? thanks
Man that is a good lookin' car!
Old Dec 25, 2021 | 04:52 PM
Sugar Bear's Avatar
Bilsteins as mentioned, they are $$ but they are really good and they last a very long time.
Old Dec 25, 2021 | 04:57 PM
69HO43's Avatar
For the '88 F41 front shocks, you'll want the GM or equivalent at least, of p/n 22046439, superseded to 22065206, and then 88945324 (still available from GM).
For the '88 F41 rear without G66 (air shock), p/n 22046440, superseded to 22046809, and finally to 88945170 (still available from GM).
A good aftermarket like KYB, is a good economical choice as well. KG4513 for front, KG5548 for rear. Around $115 for the whole set from rockauto.com.
Old Dec 25, 2021 | 05:25 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Try rockauto.com .
Old Dec 25, 2021 | 05:43 PM
The US Amazon site has basic Monroe shocks. Only the Canadian version has the Sensatrac, weird, usually the other way around.
Old Dec 25, 2021 | 06:49 PM
No longer made in USA, But china. Now called OESpectrum. The ones I just got for my 85 Eldorado are made in USA. And years ago for cutlass usa
Amazon Amazon
Amazon Amazon
Old Dec 25, 2021 | 06:57 PM
redoldsman's Avatar
Don't find any Sensatrac at Rock Auto but here is what they have:
https://www.rockauto.com/en/catalog/...+absorber,7556
Old Dec 25, 2021 | 07:25 PM
Redjetty's Avatar
Originally Posted by 69ho43
for the '88 f41 front shocks, you'll want the gm or equivalent at least, of p/n 22046439, superseded to 22065206, and then 88945324 (still available from gm).
For the '88 f41 rear without g66 (air shock), p/n 22046440, superseded to 22046809, and finally to 88945170 (still available from gm).
A good aftermarket like kyb, is a good economical choice as well. Kg4513 for front, kg5548 for rear. Around $115 for the whole set from rockauto.com.
super helpful man!!! Thanks alot!!!
Old Dec 26, 2021 | 05:14 AM
BlueCalais79's Avatar
I'm guessing my 79 Hurst Olds is going to be around the same as the suspension in your car, I went with KYB excel G's all the way around, Great ride but next time around in my 79 blue Calais which has the same suspension I may try the Bilsteins. In both cars the front springs are original but the rear coils were replaced heavy duty. I used HD springs in the rear as the standards will eventually have the car sagging in the back.
Donaldbabineau
May 24, 2021 07:33 PM
SanTan Devil
Suspension & Handling
Mar 15, 2019 02:11 PM
64F85Mark
Aug 26, 2013 09:17 AM
old98owner
Jun 20, 2012 06:52 PM
orsogrigio
22
Feb 23, 2011 09:04 AM
