1969 Hurst Olds dash question
Old Nov 4, 2021 | 10:13 AM
alsmith787's Avatar
The lower plastic dash above the radio that is sort of a arch or hood above the radio I want to install my old MAP LIGHT off the old existing dash onto the new one does anyone know what is the best tool to used to make the cutout in the new dash I'm afraid of cracking/splintering or even worse breaking the new dash panel, I know enough about cutting plastic to tape it both sides but I'm afraid to use a drill then a saw or even a razor blade
Anybody ran into this or has done it successfully??
ThanksAL
Old Nov 4, 2021 | 11:01 AM
Use a dremel and a file. Rough out the cut, use the file to make the fit clean tight. If I remember correctly there is a template in the assembly manual.
Old Nov 4, 2021 | 12:01 PM
allyolds68's Avatar
I used a dremel with a cut off wheel. As you go deeper the cut off wheels have a tendency to melt vs cut but they are easy to clean up
I'm pretty sure they chewed a hole in it at the factory....lol (the factory holes look like they were cut not stamped as well)
Old Nov 4, 2021 | 12:54 PM
alsmith787's Avatar
1969 Hurst Olds
Thanks Matt & Ally for the info
Tanner17
Mar 5, 2021 09:02 AM
Sully69
Apr 5, 2015 05:57 PM
defiant1
Apr 23, 2014 04:00 PM
copsupply
Sep 27, 2013 11:27 PM
dsolomon
Nov 24, 2010 08:23 PM
