403 Oldsmobile engine
Old Aug 4, 2021 | 04:06 PM
Skipper80's Avatar
Old Aug 4, 2021 | 05:06 PM
I don't know if you are aware 395558 is the block casting number for a 350, not a 403.
Old Aug 4, 2021 | 05:12 PM
395558 is a 350 block, not a 403. Measure the bores. They will be 4.057". The 403 has a 4.351" bore. You don't even need an inside micrometer for that.
Old Aug 4, 2021 | 06:59 PM
I was expecting a large casting number at the end, did that get stopped later on?
Old Aug 5, 2021 | 02:09 AM
Yeah, I was looking at that also, along with the different font on the casting number. It almost looks like the font used on the 455s with that "GST" casting number.
Old Aug 5, 2021 | 05:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There also would be a big 403 cast in the side of the block and possibly a X, if a 403. Let me guess, a big 8 on the heads by the number 1 and 8 spark plug. Betting it is a 73 to 76 350, a very good motor.
Old Aug 5, 2021 | 06:02 AM
edzolz's Avatar
If you look very closely, there looks like a large 1 preceeding the casting numbers.
Old Aug 5, 2021 | 06:15 AM
There were about 750 330 motors built at the very end of the 1967 model year that used 1968 350 block castings with smaller bores. This is documented in Dealer Technical Bulletin 67-T-19. I don't know if this might be one of those blocks or not. If this really is from the 1967 model year, it won't have a VIN derivative stamp on the block. These late 67 330s could have come with #4 heads or #5 heads. The DTB shows both as options.
Old Aug 5, 2021 | 06:24 AM
Is there a big "N" on the crank?
Old Aug 5, 2021 | 07:05 AM
CANADIANOLDS's Avatar
Looks like an early 350
cast crank, full length cyl walls not skirted like late 350 windowed blocks or 403
non scalloped lite weight crank
77olds
Jun 25, 2021 05:36 AM
72455
Jun 19, 2021 08:44 AM
vistacruiser67
May 18, 2012 08:58 PM
Wes Stone
Jan 24, 2012 11:57 AM
