Brake issues
Old Jun 4, 2021 | 07:30 AM
beb1980's Avatar
Brake issues
I am having some issues with my brakes on my 79 Hurst. End of last summer was braking and pedal went to floor brake light came on. This happened again this year. I replaced the control valve. Fluid is full, and no fluid leaking. Rubber vacum line and metal line to carb have no leaks as I can see. When car is in gear is when it goes to the floor and brake light comes on. In park or neutral brake feels fine no brake light comes on when brake pedal is pressed. Thanks any info would be great. Brian
Old Jun 4, 2021 | 08:48 AM
Oldsmaniac's Avatar
If no leaks, no air, I would look at replacing the master cylinder....
Old Jun 4, 2021 | 09:12 AM
X2 on the master cylinder if there are no leaks and the brakes are adjusted correctly. Normally a loss of vacuum leads to a hard brake pedal.
Old Jun 4, 2021 | 10:13 AM
armbrbr's Avatar
Not sure about this since it is only happening when in gear, but I would also check the rear drums, specifically, the adjusters and the lining thickness. Also make sure no wheel cylinders are leaking. Good luck.
Old Jun 4, 2021 | 11:14 AM
Why?
As others have said, if the pedal goes to the floor without losing fluid, it's time for a new master cylinder.
Old Jun 4, 2021 | 04:27 PM
This is a classic symptom of master cylinder failure.
Inspect the complete brake system, if nothing is excessively worn or leaking just replace the master cylinder. Not much else that can cause the pedal to sink to the floor.
Old Jun 4, 2021 | 06:05 PM
Check the back of the mc, it may be leaking there. Had that happen once, utter and total brake failure, got home on the parking brake and downshifting.
Reese Neis
Brakes/Hydraulic Systems
Sep 20, 2020 09:41 PM
veltboy618
Aug 5, 2018 10:03 AM
Hipster84Olds
30
Jun 15, 2017 04:05 PM
Dylan Conaway
Jan 14, 2017 12:41 PM
155thINF
Sep 12, 2006 05:03 AM
