68 Cutlass Read Quarter Window Weatherstrip
Old Dec 23, 2020 | 07:14 PM
Crazy68Cutlass's Avatar
I removed the rear quarter windows, regulators and motors on my 68 Cutlass S convertible to clean and rebuild.
Re-Attaching the Rear Quarter Window Vertical weatherstrip channel to the window. What is the correct adhesive to use??
I have cleaned the channel well and will clean the window with acetone before attaching.
Old Dec 24, 2020 | 04:00 AM
rob1960's Avatar
They don't use adhesive, they use a kind of rubber mounting "tape". It doesn't have any adhesive on it, it's a friction fit. You wrap it around the front of the glass & carefully tap the chrome molding onto the glass, trim the excess with a razor blade, then slide the verticle weather strip in place. If you have a good glass shop in your area they should have some, There's 2 thicknesses of the tape, our cars take the thinner of the 2 I believe. I had my local glass shop do mine, it cost me $5. Parts place does sell some pre-molded pieces for $8 a pair. They're in the "exterior moldings, mirrors & door handles" section.
jarcher442
Dec 29, 2021 05:08 PM
firstoldsmobile
Body work
Dec 17, 2020 04:37 AM
olds70supreme
Oct 16, 2014 05:04 PM
792drdelta
Aug 8, 2013 10:42 PM
shakeyhands73442
Feb 1, 2013 12:05 PM
