drive shaft???
Old Dec 7, 2020 | 12:35 PM
oldsmobilejim's Avatar
drive shaft???
Hello I have a couple questions. Is a driveshaft for a 350 turbo or a 400 turbo the same other then the length? Are the yokes interchangeable?
Thanks Oldsmobile jim
Old Dec 7, 2020 | 01:07 PM
70W-32's Avatar
Nope, they have different spline counts, with the T400 being larger
Old Dec 7, 2020 | 01:12 PM
No to both questions, actually. The yoke is larger on the TH400 and the center-to-center length is different since the TH400 is longer. Also be aware that driveshaft length is also different depending on the rear axle. The pinion flange-to-axle centerline is different on the different axles. And of course wheelbase varies with body style for some years and models.
Old Dec 8, 2020 | 08:25 AM
Phoenix8990's Avatar
When the PO installed the 455 w/TH400 trans in my 69 they had the driveshaft shortened. As I tried to clear up some vibrations in the car I found that they had not had it rebalanced. It made a difference.
Steve
Old Dec 8, 2020 | 11:05 AM
If you're converting from TH350 to TH400 you'll also need to move the trans cross member, change your intermediate e brake cables and hooks as well as install the proper kickdown linkages for the TH400.
Old Dec 8, 2020 | 11:13 AM
Apparently the OP is actually changing from a 700R4 to a TH400 (based on a PM to me), so it isn't clear where the crossmember or cables are right now.
Old Dec 9, 2020 | 06:48 PM
700-R4 replaced with turbo 400. In regards to cross-member and emergency brake cables. The cross-member fore and aft align to the same holes for the 700-R4 and the 1987 turbo 400 so same brake cable will work... Go figure I don't have that kind of luck! Yahoo.
I stand corrected the 700-R4 is a 1987 the 400 turbo is period correct BOP, and the cross-member does not align to the same holes nor does the brake cable work...
likethat
Dec 4, 2020 03:55 AM
blackngold442
Feb 26, 2013 02:10 PM
XTREMEGSXR
Jan 5, 2013 02:16 PM
Nasty455
Sep 1, 2012 02:40 PM
68conv455
Drivetrain/Differentials
Apr 11, 2008 11:48 PM
