1970 W30 engine, Is it real?
I am rebuilding a 1969 442 with a supposedly 1970 W30 motor. It has the F heads and the F block. The intake, carb and distributor has all been upgraded to current aftermarket parts. The block is currently out of the car and the heads are getting redone. My friend said you still cannot verified that this is a real W30 motor. What other identifying parts were exclusively to the 1970 W30 455 motor? Thanks
If you look at the vin stamp the pad under the driver's side towards the front. Can tell you what year.
the F heads what is the 6 digit casting number?
center just under the valve cover. I ask because
they could be E heads ground down to look like F's.
other then F heads, Intake, Distributor, Carb there wasn't any way to know if a real w30 or just a 455 with w30 heads or other w30 parts!
Note: If they're real F heads sell them to someone restoring a real w30 it'll fund a huge part of your project.
The history of the 1970 W-30 motor: Another friend of mines owned the W30 car, he sold it to another person who "rebuilt the motor". Later on this car was rear ended and totaled. The totaled W30 was sold to another friend which gave the engine to be used in my old 1969 442 since the original motor was blown. My old car sat in a garage since 1991 due to smog control restrictions in California.
Fast forward to 2020, the 442 was taken up a valuable parking space in the garage. I was offer to take the car back which I did. My friend said you cannot verify if the motor is a original W30 motor. ( He said in the 70's people were passing off 350ci truck motors with 4 bolt mains as LT1 motors).
I believe it is still the original W30 motor, but need to verify what other exclusive W30 parts belong on the engine. Are there certain part # stamped on the cam.pistons, rods, cranks...etc....?
There were 2 types of w30 cams,
1 for an auto and
1 for the 4spd.
I don't have the numbers handy right now but post what you have and the info I asked earlier.
plus the pistons should be the high compression type for that year. Not a guarantee because the standard 442 and a few others also had the high compression pistons also.
Either we can rule out No way its a w30 or it could be possible. That's the best you can get.
If your certain beyond a shadow of doubt that your freinds car was an original W30. Contact him and see if he has any piece of paper, regi, insurance, etc. That may have the W30 vin number then match it to your engines stamped numbers on block. At least that will give you some certainty. As far as proving it to the world, he would still need to have the build sheet or original sales receipt. If he ever had them to begin with.
Long shot I know....
The first question is, are they REALLY "F" heads, or are they "E" heads doctored to look like "F"? Check the casting number above the center two exhaust ports, which is typically not changed when someone makes bogus "F" heads. Real F heads have the casting number 404438. E heads have the casting number 403686. All 455s are "F" blocks. And frankly, a 1970 W-30 motor out of an automatic car is no different from any other 455 from an automatic 442 except for the heads. The cam is the same 285/287 deg cam.
Boy, your story brings back some memories!! In '77 a buddy of mine bought a '69 442/ 4 spd. Being 18 he promptly blew the 400. I lived by Niagara Falls at the time & in nearby Lockport was a junkyard that had tons of "Musclecars" I can't for the life of me remember the name of the place( anyone from western NY??) but the owner was way ahead of the times. He had pretty much everything there, all organized by brand!, even a section of wrecked vettes, The place just blew me away!. When we told him we needed an engine for a 442 he showed us 2 wrecked '70 W30s one was a stick the other was an auto!! He wanted $400 for one( you could buy low miles V8s for $50 all day long back then) & my buddy just couldn't afford it ( he was still in high school, working part time busing tables) He ended up getting a nice '70 350 4bbl instead. It wasn't hard to find stuff like that back then but who took the time(or knew to check vin #s, original paperwork, what was that!), After all they were just used cars then. The guy also had complete cars for sale. I saw my first W32 there & we were like what the hell is that!! We all knew about W30s & W31s, there were quite a few potent Olds around where I grew up but we'd never seen or heard of a W32!
So what you're left with is the F heads and a run-of-the-mill 455 engine.
No. The cam and pistons would be the only internal component specific to the W-30 engine, but as you said the engine has been rebuilt so those likely have been replaced. And the "W-30 specific" carb, distributor, and intake manifold are gone.
404 438
From what I have understood over the years, since the W30s were hand assembled "blue printed" in a separate area, the pistons had unique markings (letters) so they each would be put in a specific cylinder bore
ALL Olds motors had pistons that were sized and marked. The "select fit" W-30 motors used "A" sized pistons in "D" sized bores to get more piston-to-wall clearance.
If the W30 that matches that number is gone it’s just another 455 block. $4000 for the heads $4500 for the whole package sounds like a good starting point. Most people who would be interested in the heads would not want to ship the block IMO.
Why? There is absolutely no provenance to those heads since the car they are in is destroyed, and you are putting an incorrect size and year engine in a 69 442. There is absolutely no point to keep those heads as you could finance the entire engine rebuild, and another set of heads, and rebuild those too, for selling the F heads. If everyone is telling you this, you should listen.
Obviously do whatever you want with it, but that "preservation" ship sailed long ago.
