Maybe I'm missing something?
Old Sep 30, 2020 | 05:06 PM
72455's Avatar
1972 U code Supreme
Hey all, I posted this earlier...
https://classicoldsmobile.com/forums...ck-yet-149150/
All the after market clocks I see are the same, so am I missing something as far as installation? I was under the assumption that the repops were plug and play...is that not the case?
Thanks,
Dave
Old Sep 30, 2020 | 06:34 PM
4speed455's Avatar
I believe there are two vendors for the original clocks and the kit only works for the Borg ones. Can you post pictures of what you have and what you ordered? I’m not sure on how to ID the original one but I’m sure with pictures someone else here can.
Old Sep 30, 2020 | 06:47 PM
PatL's Avatar
Thanks,
Dave
I am not sure what you mean by three bolts? Do you mean the three screws that hold it in the frame and those do not line up ?
Old Sep 30, 2020 | 07:06 PM
72455's Avatar
1972 U code Supreme
Yup..when I put the repop into the dash, the holes on the tabs won't line up with the holes in the dash.
Old Sep 30, 2020 | 07:13 PM
From the other thread:
Can you swap the new guts into the old housing?
Old Sep 30, 2020 | 07:18 PM
72455's Avatar
1972 U code Supreme
I'd try that if I could get the old one apart, but when I turn the nuts on the back, the shaft that they are threaded onto just spin...
Old Sep 30, 2020 | 07:25 PM
Grind them off. You have replacement parts.
Old Sep 30, 2020 | 07:29 PM
72455's Avatar
1972 U code Supreme
Not a bad idea, just not sure if I wanna wreck the original.
Old Sep 30, 2020 | 07:51 PM
4speed455's Avatar
I read it wrong. I see now that you bought a complete clock. I have Parts Place reproduction tic tok tach and it has the flat spot on the bottom. Maybe the clock they sell has the flat spot?
https://www.thepartsplaceinc.com/pro...clock-new/9723
Old Sep 30, 2020 | 08:37 PM
I completely understand that; I feel the same way about a lot of original parts. But what will you do with the original that doesn't work and you can't take apart to repair? As it is now, it's garage art.
Old Oct 1, 2020 | 04:50 AM
72455's Avatar
1972 U code Supreme
I ordered one from them.. we'll see.
Old Oct 1, 2020 | 05:22 AM
oldsmobilejim's Avatar
Send it back then send the original to Redline gauge and clock repair.They did me right and reasonable.
I purchase a aftermarket Tack upon arrival the clock hand was laying at the bottom. I contact the same vendor, customer service suggested remove the plastic lens and reattach. Wrong answer so I returned for full refund.
Old Oct 1, 2020 | 05:27 AM
chip-powell's Avatar
I know that I'm coming into this late, but what is wrong with the original clock...other than it's not working? The only reason that I'm asking is because like almost everyone, my clock didn't work in my '71 when I bought it. A few years ago I took the clock over to a local watch/jewelry repair guy in my area. He fixed the clock and only charged me $40. Have you checked with any watch repair guys where you are?
Old Oct 1, 2020 | 07:10 AM
72455's Avatar
1972 U code Supreme
One of the gears popped and is dangling on the spring.
Old Oct 1, 2020 | 09:06 AM
I reiterate...have you checked with any watch repair people in your area?
Old Oct 1, 2020 | 10:01 AM
72455's Avatar
1972 U code Supreme
Just called around.. nobody in my area repairs automotive clocks.
Old Oct 1, 2020 | 10:07 AM
Oh well. It was just an idea. I'd give you the number to the guy I used, but he retired 2 years ago. I guess repairing is a dying art. Everything is just toss it out and buy new.
friesjh
Sep 23, 2020 06:35 PM
ReallyWildStuff
Mar 12, 2018 09:28 AM
66-3X2 442
Feb 14, 2017 05:34 PM
xxdarkwolf
Mar 26, 2008 09:06 AM
Oldsfan
Aug 1, 2007 09:40 AM
