Wagon Window
Old Aug 18, 2020 | 04:03 PM
F-85 4-4-2's Avatar
Wagon Window
My '65 Vista owner's manual is MIA. I can raise/lower the tailgate glass from the dash, but with the key in the tailgate keyhole, it can only be raised. Is that normal?
Old Aug 18, 2020 | 04:32 PM
Oldsmaniac's Avatar
I just put together a 67 wagon. The key in the tailgate switch should do both up and down as far as I know, however mine just stopped working in the up direction with the key switch. I swear I had it working up and down..
Old Aug 19, 2020 | 05:19 AM
Both the dash switch and the tailgate switch will raise and lower the window, so it sounds like you have either a bad switch or a broken wire in the tailgate.
Old Aug 19, 2020 | 06:56 AM
I'd imagine they're wired in parallel and do the same things.
Hrrrm. I wonder if the dash switch goes through the ign on circuit and the door switch is always hot?
Old Aug 19, 2020 | 07:25 AM
Correct.
Old Aug 19, 2020 | 01:26 PM
F-85 4-4-2's Avatar
So it wasn't a bad wire or switch, although the connector wasn't quite fully seated. Turned out that all of my keys (3), including the OEM, like to go counterclockwise in the door switch, but need "persuasion" to go clockwise. And I'm not one to force that issue.
Other than a locksmith look-see, any suggestions? A bit of graphite perhaps?
Old Aug 19, 2020 | 01:32 PM
Yes, exactly. I've frequently found that lock cylinders can stick from lack of lubrication.
66luvr
Feb 17, 2015 02:19 PM
gthmcty1
Dec 28, 2014 12:12 AM
montvaleplace
May 27, 2013 04:12 AM
rktolds
May 2, 2013 10:10 AM
oldsmojo1
Dec 29, 2009 08:27 AM
