I can't tell what your question is, but if you asking if they are were salvaging, I would focus on the rear panels (the top component is not reproduced and you need it to mount the replacement panels. The mounting hardware for the door straps (the long metal strip,etc). You can get reproduction door straps from Legendary that still need the hardware. Hang on to the rear arm rests and piston covers as they can be recovered. The front door panels are completely reproduced, but I would hang on to original trim pieces, They are wider than the reproductions.
I’m pretty sure the rear door panels are reproduced. If you meant the piston cover metal piece and the arm rest I think you just recover those existing metal parts and they do make those covers too. https://www.ebay.com/itm/1971-Oldsmo...0AAOSwFGNcWxAf
