Flip down rear license plate bracket upgrade?
Old Nov 9, 2019 | 07:08 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I hate the factory spring loaded license holder. Is there a bolt on application that isn't spring loaded? I put a F body non spring loaded bracket on my G body, they should have been like this from the factory. I will double check but pretty sure the G body has different spacing on the mount holes.
Old Nov 9, 2019 | 09:27 AM
I want a cylinder mod so I can flip it down when I run red light cameras.
Old Nov 9, 2019 | 10:12 AM
I guess I didn't realize this was a problem for the last 50 years.
How do you hold the plate up without a spring? Removing the spring from the holder is easy.
Old Nov 9, 2019 | 10:13 AM
I would think it would be pretty easy to install a F body bracket. I have t made a side by side comparison, maybe as simple as drilling new mounting holes.
Old Nov 9, 2019 | 10:16 AM
Get a F body license plate bracket, make sure you get the flip up headlight actuator while your stripping parts. Then figure out how to adapt the actuator to flip the plate. Hopefully you watched lots of McGuyver when you were younger!
Old Nov 9, 2019 | 12:13 PM
Easy to do with an electromagnet.
Old Nov 9, 2019 | 02:33 PM
That will flip it down. It won't bring it back up. The street rod community has solved this problem.
http://www.hotrodproducts.com/RetractAPlate.htm
Old Nov 9, 2019 | 04:37 PM
Matt, I'm an engineer, so I don't need MacGuyver, I just do what real engineers do, and that's apply someone else's work (like what Joe linked) to the problem and get it done, hah.
Old Nov 9, 2019 | 05:24 PM
Yeah, but if you were a MANAGER, you'd not only apply someone else's work, you'd take credit for it.
Old Nov 9, 2019 | 05:35 PM
true. I am not management material.
Old Nov 10, 2019 | 04:51 AM
I like the rear flip up plate, It's just another of the things that are "old school ". People at the gas station take a double take when they see me fill it. Part of the experience...
Old Nov 10, 2019 | 05:14 AM
Yeah I will do a comparison today, got side tracked. The B bodies also have these supposedly. The F body stays down and up, simple but works, so much nicer to fuel. Sorry, the factory was stupid with this design. It no doubt done because some people would leave the plate down, the mouse trap spring prevents it. I had a 81 Delta 88, maybe it was that way, can't remember. The 70 has a wide mounting band. The F and G body has smaller mounting tabs, so unless they are close, modifications will be needed to work.
Old Nov 10, 2019 | 05:58 AM
The 1977-1985 B/C-body brackets also have the spring. There are tabs where you insert the gas cap with the bracket down to hold it down.
Old Nov 10, 2019 | 06:28 AM
I should clarify the F body bracket is spring loaded, just kind of clicks in place on the down position and doesn't snap up. One spring on the inside on the driver's side. That is what I thought on the B body just the rumor out there. The A body mounts further in, the F and G body further out. I will need a flat bar to first bolt the F body plate to and then mark and drill for the A body mounting points. Not hard but not bolt on either. The cap is a real POS to get off on my 70S so too hands are better with one not holding the stupid license plate.
Old Nov 10, 2019 | 06:38 AM
In 45 years of driving these cars, this has never been an issue. Maybe you just need a new cap...
Old Nov 10, 2019 | 07:14 AM
Brand new cap, always been a difficult remove, daughter lost the original. Try a F body license plate bracket, it is sweet. One of those, where have you been all my life moments. I even have a ball hitch in the way and still works. The 70 is at a PIA angle which makes it much more annoying to fill than the B or G bodies. I can hardly wait, a lot of time to **** around plus with the 403 stroker I am building, gas ups will be more often.
Old Nov 10, 2019 | 07:52 AM
Yeah, same here. And putting the cap in the bracket to keep the license plate down means I won't inadvertently leave it at the gas station when I drive away.
Old Nov 10, 2019 | 07:54 AM
OLE442's Avatar
All those years I used the rear bumper, drop down license plate door to get to the filler cap on all those old GM cars.....and I never knew I had an issue with it. Well, at age 67 it probably won't bother me to use it as is for a few more years...LOL! Then, it will be someone else's problem! Imagine the issues the kids today would have with the gas filler behind the tail light like the 55-56-57 Chevrolets:
https://www.pinterest.com/pin/469781804878438564
Old Nov 10, 2019 | 12:05 PM
I lived with it, then saw people using the F body plate on G bodies, 2 minute swap. The little shitty cap doesn't work as well as the big cap on the G bodies to hold the door, plus the angle isn't as nice. Don't knock it till you try it.
Old Nov 10, 2019 | 04:16 PM
BillK's Avatar
I just got back from filling up my Wife's Riviera for her. Flip down plate and all
Old Jan 8, 2023 | 03:47 PM
jmcghee's Avatar
Installed a a G Body kit from markmonte on my 84 delta 88 Works perfect. Never had a problem with stock setup until arthritis came to visit.
Old Jan 8, 2023 | 03:59 PM
Falkon's Avatar
Holy old thread Batman. Funny, this is something I've never thought about.
Old Jan 8, 2023 | 04:12 PM
Funkwagon455's Avatar
I’ve never really considered the spring loaded plate to be all that much of an issue. Once upon a time ago, I had an electric blue, four speed ‘81 Z28 that had one of these “fill-n-go” gas caps. Maybe that would make your life less stressful.😊
Arriving fashionably late….
https://www.speedwaymotors.com/Hagan...iABEgKz8PD_BwE
Old Jan 8, 2023 | 05:40 PM
OLE442's Avatar
It’s a little funky to use a tire pressure gauge and then an air hose and chuck to fill up my air shocks but I make it happen! I actually feel a few decades younger when I’m filling up the gas!
Old Jan 9, 2023 | 04:50 AM
Bfg's Avatar
Bfg
Get an electric car!
Old Mar 16, 2023 | 08:10 PM
jmcghee's Avatar
To all the snide posters. Bless your hearts. I pray , none of you ever, have a stoke, and or arthritis
Old Sep 29, 2023 | 03:55 PM
Chesrown 67 OAI's Avatar
67 plate holder
I drove my 67 cutlass for at least 10 years before i found out that the little tab sticking up was to hold your gas cap AND hold yhe door open!🤣🤣🤣🤣🤣
Old Sep 29, 2023 | 05:16 PM
Still using it on the 70 Cutlass S, love it. Hate on it all you want.
my76cutlass
Sep 14, 2022 05:04 AM
Julle
Body work
Jun 8, 2019 06:45 AM
Dino1944
Nov 19, 2016 05:41 AM
Sully69
Aug 13, 2015 04:05 AM
Macadoo
Jul 17, 2014 06:52 PM
