2 barrel to 4 barrel carb swap on 1971 cutlass 350
Old Oct 12, 2019 | 10:47 AM
williamwallace11's Avatar
Unhappy 2 barrel to 4 barrel carb swap on 1971 cutlass 350
Hi, I had just started the swap with a OEM Rochester 4 barrel and the edelbrock performer 7111, and now having all the parts on, and a new throttle cable bracket, but when I went to start it, it will either not turn over or start and run at a 3-4000rpm idle and die out after 3-5seconds. In some cases when tinkering with the air fuel mixture I would get backfire through the carburetor. I had been surfing the internet for vacuum line diagrams and even a chilton book but cannot find any, I believe I have all my vacuum lines attached to the correct ports, I had also never taken off the distributor to change out the intake manifolds. Just looking for someone that has done the swap that maybe I do need to alter the timing or if you see any hoses I may have in the wrong place. Stuck at a cross road and not sure where else to look.
Old Oct 12, 2019 | 01:35 PM
You have a hot air choke that's not/can't be connected to anything using that manifold. You need an electric choke conversion kit. If you want to get it running the way it is, back off the idle adj scew on the right side of the cab and wire the choke open.
Old Oct 12, 2019 | 03:18 PM
For the time being while I’m waiting for the Electric Choke to come could you explain on how I could wire it open?
Old Oct 12, 2019 | 08:00 PM
Make the upper forward flap stay open, use a stop on the linkage arm and a tie wrap for example. Turn the high idle screw out.
Old Oct 12, 2019 | 08:32 PM
70W-32's Avatar
Dont know if you have the other end plugged, but you have no vacuum hose going to the brake booster
Old Oct 12, 2019 | 08:54 PM
don71's Avatar
same but different
If you can get the choke plate open for a bit, even with a screw driver or something else,you might see some improvements enough to get it started and do some other tuning.
If I were you, I'd loosen the three screws on the choke housing and take some tension off the spring by rotating it. It'll be easier to keep the choke open with what ever you choose to stick n there...
Old Oct 13, 2019 | 06:19 AM
Is your throttle cable bracket above or below the carb flange?
Old Oct 13, 2019 | 11:54 AM
Good catch.
Old Oct 13, 2019 | 06:21 PM
as of now the bracket is above the carburetor gasket
Old Oct 13, 2019 | 06:26 PM
You may have had a tremendous vacuum leak from the bracket being mounted under the flange preventing the engine from idling correctly. With the choke propped open, will it start and idle now?
Old Oct 13, 2019 | 08:49 PM
I had loosened the three screws and turned it open to where it stands vertical now, it is now at a point where it has a little pop or two like it wants to start and on the third crank a flame came back up through the carburetor. Could be the bracket where I may have to put it on top of the flange since it uses the two rear bolts for the carb to mount the bracket on.
Old Oct 13, 2019 | 09:09 PM
Check your firing order and make sure you are not 180 out on the distributor. Olds is wired CCW.
Old Oct 13, 2019 | 11:21 PM
I had never unplugged any of the spark plug wires so they are still the same as when it was running before with the old manifold and carburetor. Unless it is a different firing order now for the new carb, which I have no looked up yet.
Old Oct 14, 2019 | 06:55 AM
I would check to see if the cap got bumped and its not seated correctly. Make sure the 2 plugs at the cap are seated all the way. Turn the A/F mixture screws all the way in and the open them 4-5 turns each.
Old Oct 14, 2019 | 08:50 AM
Gpc1's Avatar
The carburetor itself may be bad, my experience has been they are either good or bad. I have taken cars that ran like crap changed the carb and they ran good after. Even rebuilt carbs can be defective. Where did you get it? Was it running ok with the old carburetor?
Old Oct 15, 2019 | 07:03 PM
I had noticed you said good catch with the throttle cable bracket and I remember my dad had it running before we had the bracket but the throttle was all over since the cable was not secured will it work better with the bracket above or below the gasket or should I file the bracket so it is thin enough to not raise the carb away on one side
Old Oct 15, 2019 | 07:17 PM
The bracket needs to be bolted ON TOP of the carb flange. Do not put it below the flange, either on top of or beneath the gasket as that will result in a massive vacuum leak.
Old Oct 15, 2019 | 07:36 PM
If you look closely, you'll notice he is measuring vacuum (gauge) via the manifold vacuum hose which runs to the brake booster.
Old Oct 15, 2019 | 07:41 PM
The answer to the bracket is below, you can install a throttle return spring on the carb to keep it in one place.
Old Oct 16, 2019 | 12:06 PM
so it needs to be below in order to run correctly with this throttle cable mount? and to an above question I am using a vacuum gauge from the manifold vacuum port
Old Oct 16, 2019 | 12:39 PM
NO!
The answer to your question is below, as in it is in the quote below this sentence.
There should not be anything between the carburetor base plate and the intake manifold except the gasket. The gasket's job is to seal the base plate to the intake, so putting the bracket either on top of or below the gasket will prevent a seal and will result in a massive vacuum leak.
The bracket should be on top of the carburetor base plate.
Old Oct 16, 2019 | 02:09 PM
Ok, maybe my quote was a bit misleading. No, as Kenneth stated in my "below quote reference" The bracket needs to be attached on top of the carb flange, not sandwiched in between the carb and intake manifold.
Old Oct 16, 2019 | 04:43 PM
After reading it over again changing it around before checking the forum again I had bolted it on top of everything and she runs great I really appreciate all the help on this thread it has been a long couple weeks of frustration with this and it’s awesome to have a community to help
Old Oct 16, 2019 | 06:42 PM
Glad your up and running.
Brian5688
Feb 8, 2018 09:10 PM
VI Cutty
Jun 3, 2017 10:40 AM
1972CutlassCar
Mar 3, 2014 06:09 PM
aaron1969
Feb 25, 2014 07:39 AM
Gee
Cars Wanted
Jan 26, 2005 12:02 PM
