Help identify these valve covers
Old Sep 7, 2019 | 05:13 PM
merk23literturbo's Avatar
I think they’re for 49-56 303-324? They need a polish but are in great condition. Thanks!
Old Sep 7, 2019 | 05:18 PM
OLDSter Ralph's Avatar
1957-58 also used a similar "2 bolt" valve cover. I am not sure if they fit anything other than 1957-58.
Old Sep 7, 2019 | 09:06 PM
edzolz's Avatar
Are you sure they are Olds? Could be Y block Ford.
Old Sep 8, 2019 | 06:55 AM
coldwar's Avatar
1949-56 Oldsmobile, and if the four pads are drilled, Studebaker V-8.
Old Sep 8, 2019 | 08:11 AM
I compared them to the 57 J2 covers and everything lines up except the height.
Old Sep 8, 2019 | 08:23 AM
It could be a casting that can be used for several several different engines. The original 1957-58 valve covers worked with hydraulic lifters. "Old style" adjustable rocker arms used with solid lifter cams of the era needed the W-1 "dimpled" valve covers cleared the adjuster screws.
rogue_ryder
Jan 31, 2019 07:53 PM
Sporty45
May 19, 2015 03:39 PM
Olds luvr
May 12, 2010 01:24 PM
shaks 442 clone
Sep 17, 2007 06:06 AM
