72 CS Dash Speed Nut Needed
Old Apr 4, 2019 | 06:44 AM
AJFink's Avatar
Question 72 CS Dash Speed Nut Needed
New to put my dash in and the speed nut that is located on the upper drivers side by the vent in mine broke. Has anyone found a replacement? I have tried a couple of other methods and have come up with nothing that will work short of trying to put a nut on it like the others that hold the dash. I got Oldspackrat on the look out for one but was hoping to get some ideas on how others have solved this conundrum.
Old Apr 4, 2019 | 07:50 AM
My442's Avatar
Question
Are you looking for the sheet metal Tinnerman nut that cuts threads on a non threaded post?
Old Apr 4, 2019 | 07:54 AM
AJFink's Avatar
Not sure if that is what its called, The post that screws into the dash has threads and this just grips the threads. It is the same post used in all the other locations that gets nuts.
Old Apr 4, 2019 | 08:19 AM
It's called a "barrel nut" or "tubular barrel clip". Auto trim clip vendors sell them.
https://henrysautowarehouse.com/prod...-clip-tubular/
Old Apr 4, 2019 | 08:35 AM
AJFink's Avatar
Thanks Joe I called them beings they come in packs of 50 and all I need is one I asked if they could send a sample of one that closely matches the hole and stud. They are going to see what they can do.
Old Apr 4, 2019 | 09:53 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
A parts store (a good one) will have them on the "Help" racks in packs of 5 or 10. Dorman part number maybe. An auto body paint/trim supply house will have them as well in smaller packs. Don't rule out the large big box home supply houses. They have a large bank of drawers with hardware. Could buy just one if they have it. Fusick Year One OPG or any of the restoration houses will have them too, thou likely not in singular quantities.
Old Apr 4, 2019 | 09:56 AM
All of which are either empty or have the parts mis-located so you can't find what you need.
Old Apr 4, 2019 | 10:04 AM
AJFink's Avatar
I have pretty much exhausted all that is offered here in our parts stores, the issue is that the hole is about 1/4" to 5/16". I found plastic ones and that does not hold that side of the dash, it just pops back out. The place that Joe offered has metal ones that are big enough for the hole so as soon as I get those samples will let everyone know how it works. I can just barely get a nut on the stud, it may have to come down to this.
Old Apr 4, 2019 | 10:25 AM
AJFink's Avatar
Precisely what has added to my frustration trying to find what I need.
Old Apr 4, 2019 | 11:38 AM
2blu442's Avatar
Tony, I've never removed one of these from a dash. But if you need it I can try to pull this without damaging it. This is on a 1972 Cutlass dash although I believe it was the same piece from 70-72. John
Old Apr 4, 2019 | 11:42 AM
AJFink's Avatar
THAT'S IT JOHN!!!!!!
Give it a try yes please do
Old Apr 4, 2019 | 12:22 PM
2blu442's Avatar
Tony, send me a PM or email with your shipping address, I'll put this in a little box and send it your way. John
Old Apr 4, 2019 | 12:37 PM
AJFink's Avatar
PM Sent..........You nailed it John your the best.
Old Apr 4, 2019 | 06:22 PM
AJ, I totally misunderstood you. This is what I thought you were talking about by the subject title and my interpretation of your first post.
The last place Id look for the clip 2blu is holding on to is a general purpose house of nuts n bolts.Hell, I doubt anyone reproduces that baby.
Steve
Old Apr 4, 2019 | 07:16 PM
2blu442's Avatar
Steve
Steve, I have found some pretty strange items in the Lowes fastener section. But I was able to get this one out without breaking it. I don't have any cars finished, but I've got a lot of cars and parts to take pictures of and sometimes pull parts off of.
chocolate apocalypse
Oct 27, 2018 04:06 PM
J.O.
Aug 14, 2017 12:24 PM
car_designer
Apr 6, 2013 05:24 AM
rmoths
Sep 6, 2012 09:11 PM
centonze
Feb 29, 2012 09:00 AM
