the 3 69 cutlasses i picked up
not in great shape but do have some good parts on them. one has a 70 to 72 console and duel gate shifter and sports wheel. also has a limited slip 10 bolt with a 4.10:1 Richmond gear. one has a TH400 that shifts very hard. the 4 door has a very beautiful A/C dash. and all the A/C is there and has full pressure on the system(well to the best i can tell without it running). all the doors but one are in top notch condition under the bottom. i cant tell what the paint may be hiding on the skins. the seam all around the doors are not blistered at all. i have a guy that wants them. i told him that i was going to keep some of the parts and give him a list of the parts i was keeping. he said he would still buy them for what i paid for them after i take the parts i want. i am not sure what i will do but i will probably sell them to him.
If I remember, there is a file size limit on the pictures.
That is going to be affected by the inherent resolution of the picture and the size of the image. When cutting your pictures down to fit the file size limit, you are better off to have a low resolution image if you want to maintain physical size. High pixel density (resolution) makes for gigantic picture file sizes. There are also some differences in file size for jpeg's and tiff's that I don't know enough about to worry over, but in terms of physical image size, lower resolution will be your friend here.
the 4 door is the only one with a factory radio and it is just AM. 3 of the wheel opening moldings are good, but 2 of those look to have had the tires rub them and bend the top under side just a little. i want to build a 68 someday and was going to keep them.
