OK next question 65 cutlass wiper motor
Old Jan 6, 2019 | 01:47 PM
brandon reynolds's Avatar
So when I got my 65 it didn’t have a wiper motor in it, but there was two in the trunk with it. Clean one up and went to put it in and it fits fine but my wires do not reach checked out the assembly manual and everyone shows a square motor not the rounded motor like I have. Does anybody have any pictures of 65 cutlasses with rounded motors and the wiring hooked up? Thanks in advance Brandon
Old Jan 6, 2019 | 05:06 PM
Gerald Nickels's Avatar
Why not show your pics it will help.
Old Jan 6, 2019 | 05:11 PM
Old Jan 6, 2019 | 05:23 PM
therobski's Avatar
Here is a few pictures of a restored 2-speed wiper motor on the 64 F-85, it may help....
Old Jan 6, 2019 | 05:37 PM
It looks like your harness has been rewrapped. Has the slack been taken out of that pigtail or possibly the harness is routed wrong?
Old Jan 6, 2019 | 05:48 PM
It hasn’t been re-wrapped it’s a brand new harness and I checked it against the old one in the pigtails are exactly the same length. Therobski, it looks like there’s a small extension harness to your wipers is that correct? Thanks for Everyone’s help Brandon
Old Jan 6, 2019 | 05:59 PM
therobski's Avatar
This is also a new harness from M@H , one plug in is for the motor the other is for the washer motor ( black plastic box) Where is your motor plug in wires from the motor?
Old Jan 6, 2019 | 06:07 PM
If you zoom in on the picture there’s three spades where the wires go into the seam next to the ground strap.
Old Jan 6, 2019 | 06:27 PM
nicks1966's Avatar
Here is a link to the harness
https://www.lectriclimited.com/wire-...harness-103145
Old Jan 6, 2019 | 06:49 PM
therobski's Avatar
There you go!
Old Jan 6, 2019 | 06:50 PM
Awesome thank you very much I didn’t see it on Mạnh his website but I’ll have to call them. Does anybody know where the brown wire with the clip goes to? Thanks for all the help guys Brandon
Old Jan 6, 2019 | 07:06 PM
nicks1966's Avatar
I believe it goes thru the firewall direct to the wiper switch.
the picture is not real clear but appears to go thru the firewall.
Old Jan 6, 2019 | 07:22 PM
Awesome thank you very much I guess what I should look at first just to make sure there’s a two speed wiper switch in their correct, as I just got this car and I don’t know much about 65. so I will check there first thing tomorrow and if there is a two speed switch I will order that jumper. If not i guess i will get a different wiper motor. Thanks Brandon
Old Jan 6, 2019 | 07:55 PM
nicks1966's Avatar
If you can post a picture of your switch, I may have a 65 two speed switch.I have a few that I am not sure of the years.
Old Jan 7, 2019 | 06:22 AM
therobski's Avatar
Just turn the switch on and see if you have 2 positions. If it's is a 2 speed you will feel a little pause..
Old Jan 7, 2019 | 07:03 AM
therobski's Avatar
I dug these up for you online...
Old Jan 7, 2019 | 03:12 PM
Great thanks for the prints. So the plot thickens never even realize this car doesn’t even have a wiper switch here’s what I have for wires. looks like a piece of a switch and a few wires hanging. Plus two unconnected wires under the dash– I will have to go through my boxes of parts that came with this car and see if there’s a wiper switch included. Thanks for all the help with this so far
Old Jan 7, 2019 | 03:18 PM
These prints only show the 2-2 wire plugs not the extension harness.
Old Jan 7, 2019 | 03:33 PM
classicmuscle442's Avatar
Believe the Cutlass got the two speed wipers and f-85 got standard single speed. Do not have my manual handy but should show it.
Old Jan 7, 2019 | 03:43 PM
OK here are some good information out of the assembly manual
Old Jan 7, 2019 | 04:34 PM
therobski's Avatar
The prints I located, yes is for a single speed but should give you some clues and my base 64 F-85 came with a 2-speed.Granny spent some extra $$ on that option!! My suggestion moving is to forward locate another switch, https://www.ecklerschevelle.com/chev...1964-1965.html
Old Jan 7, 2019 | 05:04 PM
nicks1966's Avatar
E-mail Sent
Old Jan 28, 2019 | 05:48 PM
I just want to say thanks for everybody’s help the wipers are now working great. thanks for the switch Nick.
rick442
Jun 13, 2018 07:00 AM
Sarum
Aug 2, 2014 01:54 AM
BigWelder036
Aug 11, 2012 12:33 PM
STLCRZY
Apr 17, 2012 05:49 PM
ed burke
Feb 23, 2010 10:37 PM
