wide band O2 sensor?
Old Jan 4, 2019 | 05:49 PM
442fanatic's Avatar
Has anyone installed a wide band o2 sensor and guage into your cab to monitor how rich/lean the car is running?
Had someone recommend me to get one. Or is there just a sensor one can put on the tail pipe to test when tuning?
Alex
Old Jan 4, 2019 | 06:24 PM
woodie582's Avatar
I have, AEM brand, I found it to be a plus for my tuning.
Old Jan 4, 2019 | 06:27 PM
442fanatic's Avatar
Woodie,
is it something you attach to one/both tail piples to read when you are tuning? Or a permanent guage wired in with the sensors somewhere on the exhaust pipe?
Old Jan 4, 2019 | 06:32 PM
woodie582's Avatar
Single bung welded in about 30” or so downstream on the passenger side. I have it mounted inside to get reading through the full rpm range.
Old Jan 4, 2019 | 06:51 PM
442fanatic's Avatar
Went to the AEM site, quite a few options. Did your kit come with instructions for install, what readings are the ideal?
You mentioned 30" down on passenger side. 30" down from the manifold?
Is your car a dual exhaust non crossover style?
Old Jan 5, 2019 | 01:58 AM
1970greensupreme's Avatar
if your running headers and true dual, about 4 inches or so back from collector. Manifolds, anywhere from 4-6 inches from manifold to down pipe. You can either weld a bung in the exhaust or they sell band clamp and you drill. I would weld to make sure no leaks. Basically at idle at close to sea level you want 14 to 14.7 to 1 ratio, cruising around 14-1 to 14.7-1. Wide open throttle, safer closer to 12.5-13-1. Great carb tuning aid along with setting up your distributor curve right you can optimize fuel economy and power and fix detonation problems
MY71W30
Feb 24, 2019 06:10 AM
brandon reynolds
Mar 30, 2018 02:02 PM
Onehit
Oct 10, 2011 07:38 PM
jerseyjoe
Jan 7, 2011 10:54 AM
deltaroads
Dec 17, 2010 11:40 PM
