Convertible top pump
its a pretty simple mechanism inside ,i took mine apart and cleaned it ,then replaced all the rubber orings with new ones i picked up at the hardware store .filled it with transmission fluid from a turkey baster and it works great.
Its for a 65 Cutlass. I have put a jumper directly to the pump. ( one wire to the red lead and another to the ground ) I get a spark when I touch the ground. I'm thinking something is frozen inside from sitting for a long time. I guess my next step is to disassemble the unit to take a look inside.
